Im new to the idea of using all of adt for the basement through the roof. Usually i just use line work but I was wondering whats the easiest way to make the boxed return at the end of the roof. Any help would be great.
You could generate a 2d elevation of the building model and edit the linework drawing in your box manually that way.or if your using the roof object to do your roof you could convert it to a roof slab and you can create a roof edge style that has the boxed end in it and it would show up everytime because it would be part of the roof slab object. you can also copy that style into your template drawing (if you use one) so that its always available and you dont have to go recreate it every time you draw.
