Thread: Acad.exe still running 24 hours after shutdow.
    0,0,0 The Origin
    8,570
    Default Acad.exe still running 24 hours after shutdow.
    Yesterday I had both A2006 and A2007 running. I closed them both down normally (I don't remember in what order, though). The pc was left running a background task.
    24 hours later, start work with Word, Outlook, Firefox but NOT acad. Everything is very slow so CTRL-ALT-DEL and taskmanager shows that acad.exe is using 98% of the processor time. Terminating the process restored everything to normal.
    Strange, eh?
    I could stop if I wanted to Ogre's Avatar
    2005-06
    In the end, Cauliflower is just albino Broccoli
    288
    Default Re: Acad.exe still running 24 hours after shutdow.
    That is wierd ...I also have a little problem specifically with A2006 opening...Whenever it opens really slow, I open up the processes and turn off WSCommCntr1.exe and it opens up fine...Anyone else with a similar problem?
    Active Member powermarc's Avatar
    2003-10
    Seattle, WA
    52
    Quote Originally Posted by Ray.Mendoza
    Apparently there are others with the same problem:
    http://discussion.autodesk.com/threa...hreadID=366848
    Hope that helps a little.
    13,656
    <SNIP> Whenever it opens really slow, I open up the processes and turn off WSCommCntr1.exe and it opens up fine...Anyone else with a similar problem?
    Hi
    Plus, the following might be of some interest...
    Communication Center causes hang ups in 2004 and 2005
    fail to get commcntrcontroller! error
    Disable the Communication Center
    Have a good one, Mike
  1. How to prevent ACAD.lsp from running in ACAD2010?
    By vaughndave in forum AutoCAD General
    Last Post: 2010-02-16, 09:25 PM
  2. NEW WORK!!! I'VE JUST GOT A ACAD 2009 A FEW HOURS AGO
    By datadrainsiii in forum AutoCAD Gallery
    Last Post: 2008-12-06, 05:47 AM
  3. Running ACAD LT 2007 on Win64 and a 64-bit processor
    By blynn in forum AutoCAD LT - General
    Last Post: 2006-10-13, 08:30 PM
  4. Running Excel from ACAD
    By MikeJarosz in forum VBA/COM Interop
    Last Post: 2006-07-14, 05:14 PM
