Results 1 to 6 of 6
Thread: room tags not showing in sheet
    Member belyo's Avatar
    2006-04
    33
    Angry room tags not showing in sheet
    i have my floor plan... go to do an enlarged plan and my room tags aren't able to be viewed on the sheet.
    I've checked all the visability settings in all relevant views...
    thanks...
    Brian
    I could stop if I wanted to funkman's Avatar
    2003-10
    Sydney, Australia
    437
    Default Re: room tags not showing in sheet
    Room tags are view specific. Place a room tag in the new view and the tag will be completed from the parent view so long as you are in the same phase.
    2006-04
    33
    Unhappy Re: room tags not showing in sheet
    so do you divide the bldg into 1/8" sheets right off the bat and tag the sheet view...?? it seems like there is something i'm missing...
    2003-04
    Chino, CA
    4,756
    you can cut and paste room tags from the overall view to the partial views. Thats probably the quickest.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    All tags are view specific, so in each view you need to place the tags you want in that view. rooms know what they are so its easy. You can also, just use the copy/paste align tool to grab room tags from one view and paste them to another.
    The reason for this is flexibility, you may want one room tag that shows area on some plans and one that shows finish info on others. Its not like xrefs.
    Scott D. Brown, AIA
    BECK
    100 Club m.thomas's Avatar
    2004-08
    UK
    153
    Quote Originally Posted by sbrown
    Thanks goodness it's not like x-refs.... oh the pain of having multiple layers with different scaled room. door and window tags!
  1. 2012: Room Tags were showing and Now they are not.
    By gabrielle.henery in forum Revit Architecture - General
    Last Post: 2012-12-05, 09:06 PM
  2. Most Room tags are not showing up but spaces are.
    By Imwezal in forum Revit MEP - General
    Last Post: 2010-09-19, 02:40 PM
  3. room tags not showing on plans
    By jamie santiago in forum Revit Architecture - General
    Last Post: 2009-06-24, 07:01 AM
  4. Doors/Room Tags not showing up
    By edolecek in forum AutoCAD General
    Last Post: 2009-05-01, 06:49 PM
  5. New Room Tags not showing on some views
    By Griff in forum Revit Architecture - General
    Last Post: 2004-02-13, 03:51 PM
