Results 1 to 10 of 11
Thread: Draw Rectangle, prompt for length and width, then extrude to chosen height
    2004-10
    austin, texas
    34
    Default Draw Rectangle, prompt for length and width, then extrude to chosen height
    can any one please make me a lisp to draw a rectangle.....i also want it to prompt me for length and width....and then extrude it and prompt me for a depth depth....
    please respond to my e-mail
    rico72dominguez@aol.com
    2005-08
    1,043
    Default Re: Draw Rectangle, prompt for length and width, then extrude to chosen height
    (defun c:DrawExtRec ()
    (command "_.rectangle"
     pause
     (strcat
      (rtos (getdist "\n Length of rectange (x direction): ") 2 6)
      (rtos (getdist "\n Width of rectange (y direction): ") 2 6)
     "_.extrude"
     (entlast)
     (getdist "\n Thickness of rectangle: ")
    2003-11
    YUL
    75
    or...> 3dr <
    (defun c:3dr (/ l w d ip)
      (setq l (getdist "\n Length?: ")
    	w (getdist "\n Width?: ")
    	d (getdist "\n Depth?: ")
    	ip (getpoint "\n Insert: "))
      (command "_.box" ip "l" l w d)
      (princ))
    2004-07
    Detroit Michigan
    2,508
    Do you need AutoCad 2007 to get the box command?
    I have it
    2003-11
    YUL
    75
    Quote Originally Posted by Robert.Hall
    I have it
    Just AutoCAD, any version. It is built-in command.
    2004-10
    austin, texas
    34
    you guys are awesome they work great
    2005-08
    1,043
    I prefer to keep all help here. In an email sent to me
    how do i get your lisf file to default to 2.5 in the y and extrude to 3.5
    automatically and then prompt the align after it draws the box??
    thanks for your help
     pause
     (strcat
      (rtos (getdist "
      (rtos (getdist "
     "_.extrude"
     (entlast)
     (getdist "
    You would do it like this
     pause
     (strcat
      (if (not (setq tmpDist (getdist \n Length of rectange (y direction) <2.5>: )))
       "2.5"
       (rtos tmpDist 2 6)
     "_.extrude"
     (entlast)
     3.5
    Now for the align part, I'm not sure. I don't use the command, so maybe someone can help with that.
    2004-10
    austin, texas
    34
    tim
    i keep getting an the following
    error: no function definition: Y
    2005-08
    1,043
    Sorry about that. I forgot to add quotes around the question to getdist. This works for me now.
    (defun c:DrawExtRec (/ tmpDist)
     pause
     (strcat
      (if (not (setq tmpDist (getdist "\n Length of rectange (y direction) <2.5>: ")))
       "2.5"
       (rtos tmpDist 2 6)
     "_.extrude"
     (entlast)
     3.5
    2004-10
    austin, texas
    34
    tim
    thanks that works great
  1. Draw a Rectangle using the @ symbol
    By chad.beussink in forum AutoLISP
    Last Post: 2007-05-24, 01:03 PM
  2. Replies: 10
    Last Post: 2006-06-13, 09:44 PM
  3. Guide to help draw brick and block walls to the proper height & length
    By andrewp in forum CAD Management - General
    Last Post: 2005-12-12, 02:11 PM
  4. Pline Width to rectangle
    By cgerhardt in forum AutoLISP
    Last Post: 2005-12-01, 08:06 PM
  5. See the outline of a line or rectangle as you draw it
    By nanoaguilar2000 in forum AutoCAD General
    Last Post: 2005-03-31, 08:23 AM
