Results 1 to 10 of 11
Thread: Insert file w/c in a DWG that automatically updates the filename, time and creator
    2006-05
    68
    Default Insert file w/c in a DWG that automatically updates the filename, time and creator
    i also would like to know how i can create a file w/c i can insert in a drawing that automatically updates the filename, time and the creator....
    thanks.
    2002-09
    Madison, WI
    5,687
    Default Re: Insert file w/c in a DWG that automatically updates the filename, time and creator
    We created a title bar that has such info included in it. It uses a .vlx program called ltext. It's a piece of freeware from dotsoft. It works great, but can cause some headache when you do a -wblock. It fills in the name of the full drawing path along with the "User" that saved it last (I think or it's the first person that saved it). It works kind of like a diesel string, but gets applied to a piece of text. Hope this helps.
    13,656
    Quote Originally Posted by jlizann
    Hi
    Please explain file w/c as the terms does not mean anything to myself. Sorry.
    Plus, have you looked into such things, as...
    * RText.
    * Fields.
    * Sheet Sets.
    Have a good one, Mike
    Earth
    9,803
    Quote Originally Posted by Mike.Perry
    Maybe http://acronyms.thefreedictionary.com/W%2FC
    R.K. McSwain | CAD Panacea |
    0,0,0 The Origin
    8,570
    Quote Originally Posted by rkmcswain
    but maybe not.
    W/C Water-Cement Ration (concrete mix design)
    W/C Week Closing (referring to a date or deadline)
    W/C Week Commencing
    W/C Wheel Chair
    W/C With Comment
    W/C Work Center
    W/C Workers Compensation policy (insurance)
    W/C Working Capital
    W/C Wound Care
    2006-05
    68
    sorry, i mean i'd like to create a text that can be inserted in a drawing and if save that drawing, that text that i inserted will update the filename, time that is being saved and the creator. thanks!!!
    Earth
    9,803
    Just create an MTEXT entity including the appropriate FIELDS
    13,656
    Hi
    No sorry necessary.
    Ok! now I understand... take a look at the methods I listed above.
    Last edited by Mike.Perry; 2006-06-17 at 08:14 PM. Reason: :Oops: missed closing /
    2006-05
    68
    IThanks for your replies,
    I already created an attribute but is there a possible way wherein the attribute block will update itself (for ex. file path & time it was modified) everytime you hit save while in the project?
    Earth
    9,803
    Sure, but what field type are you using? The DATE field remains static until UPDATEFIELD is executed. See http://rkmcswain.blogspot.com/2005/0...in-fields.html for an idea on how to create a date field that auto-updates
  1. Replies: 25
    Last Post: 2012-11-14, 10:01 AM
  2. Insert filename into macro?
    By metron4 in forum AutoCAD Customization
    Last Post: 2011-03-07, 09:59 PM
  3. Extracting filename automatically
    By Fahad.Shuja in forum AutoCAD Customization
    Last Post: 2007-07-21, 04:33 AM
  4. Extracting filename automatically
    By Fahad.Shuja in forum Vault - General
    Last Post: 2007-07-17, 06:58 PM
  5. Dimension automatically updates as Line Object is amended?
    By dduggins in forum AutoCAD General
    Last Post: 2005-11-29, 02:29 PM
