Thread: Tracking components in project that increase file size
    All AUGI, all the time DanielleAnderson's Avatar
    2004-06
    Mostly in Mom-land
    704
    Default Tracking components in project that increase file size
    I have a fairly simple early-schematic model. I started out by importing (linking) the autocad site plan and then working off of that. Then, it was decided that there would be two identical buildings on the site (at least for now), so I decided to link the building model into a site twice, to save on modeling time.
    The problem is: after I imported the site plan, the file was loading really slowly, so I went back to the autocad drawing and discovered that it contained raster images that were turned off, making it a large file. I deleted and purged the images in the autocad file, then went back to Revit - no change, still slow loading. So I went into revit and purged decals and checked to see that there were no raster images attached. The file is still pretty large, like 27megs for a +/- 20,000sf building that has basically walls, floors and roofs, no groups, and one repeated truss family, and it is taking about 5 minutes to open.
    I wish there was some way to audit in Revit or to know the size of each component so that I could tell what is slowing me down.
    Any other ideas on what could be going wrong?
    Thanks!
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    Default Re: Tracking components in project that increase file size
    Danielle... try doing a save-as and compacting the file; that may bring the size down. Complex geometries seem to add the most to a file's size. Acad drawings seem to hurt the most in terms of plan display performance tho -- esp hatching...
  1. Increase size of preview window
    Last Post: 2012-07-05, 07:08 PM
  2. Do Instance Parameters Increase File Size
    By markleasor in forum Revit Architecture - General
    Last Post: 2011-05-06, 03:51 AM
  3. File Size Increase
    By kane333 in forum AutoCAD General
    Last Post: 2009-03-03, 06:59 PM
  4. Increase dot size of dots within dotted linetype
    By davis.sw in forum AutoCAD General
    Last Post: 2006-07-10, 07:04 PM
  5. How to increase the size of a perspective image
    By Jason in forum Revit Architecture - General
    Last Post: 2004-11-18, 02:55 AM
