My right-click short cut menu does not appear to have the default commands and options.
Which cui do I need to reload or adjust or is there a variable that needs to be changed?
I am using ADT 2006 Service Pack 1.
Have you checked your right click customization under your options-->user preferences tab?Originally Posted by bjensen.48049
I came across this problem some time ago and reloading the profile seemed to resolve it. Maybe you could give it a try.
I have checked my user preferences and there doesn't look to have anything missing, I have even entirely removed ADT 2006 and reloaded the program and still there seem to be items missing from my right-click short-cut menu that is on other machines that have been recently loaded. I don't know if there is a problem in my computer registry but something has stuck in there and won't let go.
Thank you for your thoughts and help.
What's missing?Originally Posted by bjensen.48049
I am missing ;
Isolate Objects
Basic modify Tools
I know these are not a huge problem to not have in the right-click short cut menu, but it would be nice to have them there.
This came about when I was going through the tutorial in Paul F. Aubin's "Mastering Autodesk Architectural Desktop 2006". I keep having to type in the commands (yes I'm a big weenie) or search for them in drop down menus and that is getting a little annoying.
I've heard there was an error within the latest releases of AutoCAD on this and they were never fixed? Here's the work around to get the options to stick...
Options...User Preferences Tab...Windows Standard Behavior...Check the Shortcut menus in drawing area box...click on Right-click Customization...Default Mode...Check the Repeat Last Command option...Edit Mode...Check the Shortcut Menu...Command Mode...Check ENTER. These settings should stick.
