Results 1 to 8 of 8
Thread: Coordinate System
    2006-05
    Richmond, Indiana
    139
    Default Coordinate System
    I've got a building with extremely complicated geometry, and would like to use the "hidden" coordinate grid to locate critical building points. There is really no way to cleanly dimension the building. I know you can report the coordinates at a point. But is there a way to create a tag that reports the coordinates at a point with a leader leader, etc.?
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Coordinate System
    i don't think you can in Revit.
    I'd say your best bet would be to use a standard grid system, and either dimension or align critical points to the grid lines or intersections.
    AUGI Addict bowlingbrad's Avatar
    2003-11
    Chicago
    1,233
    Reference planes on a separate workset?
    Brad Novak
    Director of Information Technology
    Gp GOETTSCH PARTNERS
    Chicago, IL
    Revit Founder LRaiz's Avatar
    2003-07
    Newton, MA
    714
    Did you try Spot Dimension tool? It looks like Spot Coordinates option of this tool does what you want.
    Leonid Raiz
    2005-12
    86
    You mean 3D X, Y, Z points, rather than the 2D X,Y points and levels you can get from the Spot Dimension tool?
    2003-05
    Waterville, Maine
    1,748
    Dang, when did this show up?? Nice feature.
    2006-05
    Richmond, Indiana
    139
    Quote Originally Posted by Revitator
    I want the 2D x,y information in plan. I can extract the information with the [tools] and [shared coordinates] and [report coordinates at a point]. I'm just trying to figure out a way to build this information into a tag to save the trouble of manually reporting the information with this tool and then having to type it in somewhere. I know Revit doesn't want to be a grid based system. But all that effort to extract information that's already there seems anti-Revit
    2003-05
    Waterville, Maine
    1,748
    You can with the spot dimension tool, as Leonid suggests above. Read the help section on spot coordinates, & you'll see how.
  1. 2015: coordinate system
    By rmk in forum AutoCAD General
    Last Post: 2015-03-27, 09:33 PM
  2. Replies: 0
    Last Post: 2011-01-25, 05:59 AM
  3. coordinate system problem
    By bhron_d in forum AutoCAD General
    Last Post: 2010-05-21, 02:13 PM
  4. NED coordinate system correlation
    By coondog45 in forum AutoCAD Map 3D - General
    Last Post: 2008-01-07, 02:43 PM
  5. How to draw a Coordinate system?
    By Olaf.Banckaert in forum ACA General
    Last Post: 2006-03-23, 02:33 PM
