Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Naming conventions for Dim Styles and Text Styles
  1. #11
    2005-06
    in the upper right corner
    3,507
    Thumbs up Re: Naming conventions for Dim Styles and Text Styles
    We name our Dim styles like:
    STD_14, (1/4" = 1')
    STD_112 (1-1/2"=1')
    STD_50 (1"=50')
    STD_200 (1"=200')
    and so on.
    They all use the text style "STD_DIM" which has a height of zero.
    This way we can change the font assigned to it and all are updated.
    Our "standard" text style is like our standard dimension text style, it's called
    STD_TXT which has no assigned height. Plotted hight of 1/8".
    "STD" just stands for our company STanDard.
    Ted
  2. #12
    I could stop if I wanted to CEHill's Avatar
    2006-05
    TN
    327
    Smile Re: Naming conventions for Dim Styles and Text Styles
    BACKGROUND
    I err on the side of being a spoiled paper space user since 2K. With a job change in 2005, I subjected myself to a combined 'model space only' and other CADD paradigm. I am currently enduring and adjusting to this 'terrible' combination. Humiliating, humbling...yes!
    CHANGE MY (little) WORLD
    I have a contract opportunity to not only work in AutoCAD but set up working CADD standards. Being a force of one there, I want to do it right including documenting standards, introducing automated routines, etc.
    YOUR CONTRIBUTIONS
    The preceding information has been invaluable in giving me ideas on how to proceed.
    AUGI members are the best!
    Yours,
    Clint
    Hill
    CAD Systems Operation and Management
    Chemical Plant Process + Mechanical Design Focus Areas
  3. #13
    Member daniel.dennin's Avatar
    2015-11
    42
    Default Re: Naming conventions for Dim Styles and Text Styles
    As far as setting up standards, take a few minutes to analyze what your needs are and what works for you. There is an article titled something like "What every CAD Manager should know" that I believe is on the AUGI site that covers some good points.
    Some key items to keep in mind:
    - Keep names in a simple format for both internal and external users.
    - Compliance with external standards such as Y14.100, Y14.1, etc for text heights, formats, etc.
    - Get input from your team and your customers as to what works and what doesn't. Comments like "We've always done it that way." demand a response of "Why?"
  4. #14
    I could stop if I wanted to johan d's Avatar
    2006-01
    Belgium
    287
    This is ours
  5. #15
    2016-12
    4
    As a suggestion, sometimes more accuracy is needed than other times. Having an accuracy component in the name could be useful.
    The problem is with every component the number of combinations multiplies...
  6. #16
    2021-01
    Charlotte, NC
    3
    Well seems like a lot of work.. go with Annotative .... Less mess.
  7. #17
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Quote Originally Posted by cadprodesign78 View Post
    I do not recall Annotative being a thing at that time.
  8. #18
    2005-06
    3,507
    True, I believe annotative text came out in 2008?
    This thread was started wayy before that.
    I still use scale-named dimstyles though
  9. #19
    2001-03
    Tallahassee, FL USA
    3,665
    I try to keep things as simple and understandable as possible.
    Dimensions are descriptive & mostly Annotative
    Anno 0.18 for Annotative dimension with text height of 0.18
    All Text Style names match the name of the font.
    Arial Narrow for font TT Arial Narrow
    Linetype files are named to match the fonts they reference as well.
    Arial.lin includes linetypes:
    *ArialTriangle,Solid Triangle__/_\_/_\__/_\_/_\_/_\_
    S,.000000001,-.05,["\U+25BA",Arial,S=0.02,R=90,Y=-.0019],-.05
    *ArialAHead,Arrowhead > > > > > > >
    A,.000001,-3,["\U+25BA",Arial,S=3,R=0,X=-1.35,Y=-1.35],.000001,-4
    *ArialARROW,Arrow1 > > > > > > >
    S,.000001,-3,["\U+25AC",Arial,S=3,R=0,X=-1.35,Y=-1.05],.000001,["\U+25BA",Arial,S=3,R=0,X=0.5,Y=-1.42],.000001,-4
    *ArialDOT,Dot . . . . . . . . . . . . . . . . . . . . . . . .
    A,0,-.125,["\U+2022",Arial,S=.05,Y=-.024],-.125
    *ArialDOT2,Dot (.5x) ........................................
    A,0,-.0625,["\U+2022",Arial,S=.05,Y=-.012],-.0625
    *ArialDOTX2,Dot (2x) . . . . . . . . . . . . . .
    A,0,-.25,["\U+2022",Arial,S=.05,Y=-.048],-.25
  1. layers, text styles, dim styles on tool palette
    By jledgewood in forum AutoCAD Customization
    Last Post: 2010-05-24, 03:30 PM
  2. More naming conventions - text styles
    By ron.sanpedro in forum Revit Architecture - General
    Last Post: 2007-07-09, 11:19 PM
  3. Sharing standard Dimension styles, text styles, hatch patterns, etc
    By dhavalpatel_us337373 in forum AutoCAD General
    Last Post: 2007-02-02, 08:34 PM
  4. Setup Correct Layers,Dim Styles,Text Styles
    By rhayes.99001 in forum AutoLISP
    Last Post: 2007-01-23, 05:49 PM
  5. Link Text with Object Styles & Line Styles
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2004-07-15, 04:27 PM
