Thread: Generating Elevations
    All AUGI, all the time BCrouse's Avatar
    2003-04
    Bethlehem, PA
    980
    Question Generating Elevations
    When you generate elevation from floor plans. How do you get the wall lines where you have a bump out in elevation to become darker?
    2002-09
    Madison, WI
    5,688
    Default Re: Generating Elevations
    You can set that up with "sub-divisions" in the elevation depth. Highlight the elevation view area, go to the properties and add a sub-division. In the 2d display style, you can then set the line weights to corrispond with each division.
    I've attached an example.
  1. Replies: 1
    Last Post: 2013-03-24, 07:39 AM
  2. Generating Interior Elevations - How many is too many...?
    By alex244563 in forum Revit Architecture - United Kingdom
    Last Post: 2012-09-14, 06:32 PM
  3. fatal error when generating sections or elevations
    By kgomez in forum Revit MEP - General
    Last Post: 2011-05-11, 03:18 PM
  4. generating boundary
    By mdsalman2003 in forum AutoLISP
    Last Post: 2009-12-03, 01:28 PM
  5. Generating a .plt file????
    By d2b.inc in forum AMEP General
    Last Post: 2006-12-12, 07:53 PM
