Thread: Quick Leader Settings
    I could stop if I wanted to H.Hunter's Avatar
    2005-08
    Somewhere, but not here
    241
    Default Quick Leader Settings
    When in the Quick Leader command (and this only works for quick leader), you can Right-Click before selecting the first point to bring up a settings window. This controls your default leader settings. Things you can change:
    • End style (Arrowhead)
    • Straight or spline leader lines
    • Number of points (or bends) in the leader line
    • Angle constraints for your lines
    • Text justification for both Left and Right side text
    • What the annotation is (block, text, etc). The annotation is then associated with the leader (how it normally handles text).
    2005-01
    185
    Default Re: Quick Leader Settings
    Does anyone know what variable controls the multi-line text attachment? I have a lisp routine that utulises the qleader command, but if this is set wrong, it messes up.
    2004-08
    Iron Station, NC
    3,197
    try this, it is a program that will allow you to set up your qleader settings, and save them so they can be recalled using a simple lisp routine and always set current.
    Christopher T. Cowgill, P.E.
    Autodesk Expert Elite
    AEC Collection Civil 3D 2020
    Windows 10
    150700
    3,434
    Quote Originally Posted by H.Hunter
    This is the perfect type of thing to be set up in your template drawing - set it once, and forget it, as long as you create new drawings based off your template drawing with these settings.
    You can also access this menu by hitting S after you start your command, hitting enter after you start your command, or, if you are using dynamic input, the down arrow and settings.
    Good tip, Jason
    2004-07
    Detroit Michigan
    2,508
    I agree with the power of template files.
    Too bad I had to inherit thousands of files that did not use a template.
  1. Multileader vs quick leader with hatch
    By jpduhon in forum AutoCAD Annotation
    Last Post: 2008-03-01, 04:10 AM
  2. wall tag leader settings
    By tim.101799 in forum Revit Architecture - General
    Last Post: 2007-07-09, 07:58 PM
  3. Quick Leader & mtext
    By jkramer in forum ACA General
    Last Post: 2007-01-11, 08:16 PM
  4. Quick Leader Gap
    By jfields.61630 in forum AutoCAD General
    Last Post: 2006-03-01, 07:40 PM
  5. Quick leader to a block
    By JOHN.73561 in forum AutoCAD Tips & Tricks
    Last Post: 2005-03-03, 09:39 PM
