chris.73431
Hello all,
Warning: do not even attempt to start to think about this unless you are either A. one of the REVIT Founders, B. a card carrying member of the REVIT GURU Association, or C. you just have too much time on your hands.
Okay, now for the question: Can you control one Family Instance Parameter to be different in separate views? Example: you want your family instance parameter to be 10' high in one view, then show as 5' high in the other. We want to simultaneously show two different configurations in two side-by-side views.
Currently, we are experimenting with this by establishing a Shared Parameter which we will link to our Instance Parameter. but how to show the same family in two configurations (instances) ?
Thank you for your consideration. The solution to this exercise may provide valuable information regarding other good tips and tricks, a better way of doing things like this, or even find the cure for the common cold. We all try and do our part. I appreciate any advice.
