Thread: How to convert Plot Lisp routine to VBA
    Southampton, UK
    7
    Question How to convert Plot Lisp routine to VBA
    I am looking for advice on creating my first VBA routine. I would like to include the lisp command shown below, into a user form, so a user can pick this (or additional options) and allow admin colleagues open a drawing and produce A3 plans without any knowledge of CAD. I can create the user forms OK, but cannot workout how to include the lisp command.
    Anyone able to help me.
    the lisp command is:
    (defun C:MMSA3 ()
    (command "-plot" "Y" "Building Blueprint" "colour A3-th"
    "A3 297 x 419 mm" "" "Portrait" "n" "E" "F" "C" "y" "pdf fine" "n" "n" "n" "n" "n" "n" "y")
    2002-02
    Kansas
    487
    Default Re: How to convert Plot Lisp routine to VBA
    Quote Originally Posted by ian.cook
    (defun C:MMSA3 ()
    use the sendcommand in AutoCAD VBA it works the same as the command function in lisp. use vbCr where you would need to use the enter key in the command
    ThisDrawing.SendCommand "-plot" & vbCr &  vbCr  & "Y" &  vbCr  "Building Blueprint"_
    & vbCr & "colour A3-th" & vbCr & "A3 297 x 419 mm" & vbCr & vbCr  & "Portrait"_
     & vbCr & "n" & vbCr & "E" & vbCr & "F" "C" & vbCr &  "y" & vbCr &"pdf fine"_
     & vbCr & "n" & vbCr & "n" & vbCr & "n" & vbCr & "n"& vbCr & "n"& vbCr & "n"& vbCr & "y"
    or this will run the mmsa3 command if it is loaded
    thisdrawing.sendcommand "mmsa3" & vbCr
    but the right way to do it is with PlotToDevice or PlotToFile method of the acadplot object check in help for how to use.
    ThisDrawing.Plot.PlotToDevice
    ThisDrawing.Plot.PlotToFile
    We make plot files for all are drawing plots and save them were nonautocad use can open then if they need to view a drawing. And if we need to plot them we just send the plot file to the plotter. We use ViewCompanion a program for viewing HPG files. ViewCompanion will also convent to PDF for emailing the file to nonautocad user.
    Southampton, UK
    7
    Thanks for pointing me in the right direction.
    2002-08
    7
    Hy,
    (Sorry for my english, i am a french user!)
    After that litle explanation a partial sub to make a layout, with a block named
    for exemple :
    "6000_cadre_A3" ~ 286 mmm x 409 mm
    The version of AutoCAD is usefull to put the good value to
    "backgroundplot".
    If there is no plotteur (traceur in french) "Aucun" or ""
    put Traceur0.pc3 by default. with an extra dimension A0++(more 2 A4 widh an 900mm)
    "User257"
    With this method you can make an automatic view in a layout with a search of the name of the block.
    The debugg is not finished but it is an exemple of all problem find, to do that.
    Daniel OLIVES
    FRANCE Lyon
    Sub TPSImprime()
        Dim objPresentation As AcadLayout
        Dim Layouts As AcadLayouts
        Dim objPlotDevices As Variant
        Dim objTraceur As AcadPlot
        Dim objElem As Object               ' objet Elément du dessin
        Dim Version As String
        Version = ThisDrawing.Application.Version
        ' ou idem
        Dim Ver As String
        Ver = ThisDrawing.GetVariable("ACADVER")
        Dim ScaleCart As Variant, AngCart As Variant
        Dim PlotEch As Variant
        Set objPresentation = ThisDrawing.ActiveLayout
        Set Layouts = ThisDrawing.Layouts
        Dim CoinBasX As Double, CoinBasY As Double, CoinHautX As Double, CoinHautY As Double
        Dim pt1(0 To 2) As Double
        Dim pt2(0 To 2) As Double
        Dim pt3(0 To 2) As Double
        Dim pt4(0 To 2) As Double
        Dim ptz1(0 To 1) As Double
        Dim ptz2(0 To 1) As Double
        Dim plineObj As AcadPolyline
        Dim points(0 To 11) As Double
        Dim FlagImp As Integer
        FlagImp = 0
    ' - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 01
        ' Test si un traceur est défini
        If objPresentation.ConfigName = "Aucun" Or _
                Left(objPresentation.ConfigName, 7) = "Traceur" Or _
                objPresentation.ConfigName = "" Then
            ' Traceur par défaut "Traceur0.pc3"
            objPresentation.ConfigName = "Traceur0.pc3"
            ' à tester
            ' Taille de papier par défaut A0++
            objPresentation.CanonicalMediaName = "User257"
            objPresentation.SetCustomScale 1, 1
            objPresentation.PaperUnits = acMillimeters ' unité papier
            ThisDrawing.Regen acAllViewports
        End If
    ' - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 02
        For Each objElem In objPresentation.Block      '.PaperSpace
            ' si l'élément est un bloc
            With objElem
                If .EntityType = acBlockReference Then
                    Select Case UCase(.name)
                        ' point 3D fenêtre selon cadre
                       Case "6000_CADRE_A3"
                            CoinBasX = -201.5: CoinBasY = 2.1
                            CoinHautX = 207.58: CoinHautY = 286.62
                            objPresentation.ConfigName = "Couleur.pc3"
                            If objPresentation.name <> "Model" _
                                    Then objPresentation.name = "A3_" & objPresentation.name
                            ' "ISO A3 -" = "A3"
                            objPresentation.CanonicalMediaName = "A3"
                            FlagImp = FlagImp + 1
                        Case Else
                    End Select
                End If
            End With
        Next objElem
        ' Cas ou il y a plusieurs blocs cadre
        If FlagImp > 1 Then _
            MsgBox ("Il y a " & FlagImp & " blocs de cadre dans cette présentation !" _
                    & vbCrLf & _
                    "La mise en page est faite sur le dernier trouvé !")
        If FlagImp = 0 Then msg = MsgBox("Pas de cadre bloc connu !", vbInformation, "Technip TPS"): Exit Sub
    ' - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 03
        pt1(0) = CoinBasX: pt1(1) = CoinBasY: pt1(2) = 0
        pt2(0) = CoinHautX: pt2(1) = CoinHautY: pt2(2) = 0
        ' Transfert point 3D vers point 2D
        ptz1(0) = pt1(0)
        ptz2(0) = pt2(0)
        ptz1(1) = pt1(1)
        ptz2(1) = pt2(1)
        ThisDrawing.Application.ZoomWindow pt1, pt2          ' zoom fenêtre
        ' Cas ou tous les points à zéro, pas de fenêtre !
        If ptz1(0) = 0 And ptz2(1) = 0 And ptz1(1) = 0 And ptz2(1) = 0 Then
            MsgBox "Il n'y a pas de cadre bloc dans cette présentation"
        Else
            objPresentation.PlotType = acWindow             ' Présentation fenêtre
            objPresentation.SetWindowToPlot ptz1, ptz2
            ThisDrawing.Regen acAllViewports                        ' pour prise en compte
    '        objPresentation.RefreshPlotDeviceInfo                  ' bugg le format ?? en pouce !!
    ' - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 04
            On Error Resume Next
            ' Prépare variable "Backgroundplot" selon version acad
            Select Case UCase(Version)
              Case "15.1S (LMS TECH)" ' Acad 2004
                ThisDrawing.Plot.DisplayPlotPreview acFullPreview   ' Prévisualisation
              Case "16.2S (LMS TECH)", "16.1S (LMS TECH)"           ' Acad 2006 ou 2005
                ThisDrawing.SetVariable "BACKGROUNDPLOT", 0         ' sans tache de fond
    '           ThisDrawing.Plot.PlotToDevice                       ' ne pas mettre en commentaire pour impression
                ThisDrawing.SetVariable "BACKGROUNDPLOT", 2         ' avec tache de fond
              Case Else
            End Select
        End If  ' Tous les points à zéro
    End Sub
    [ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]
    Last edited by Opie; 2006-07-11 at 01:11 PM. Reason: [code] tags added. See Moderator comment.
  1. Replies: 7
    Last Post: 2016-06-17, 01:13 PM
  2. Help with a lisp routine to add a 12" line to this routine
    By Orbytal.edge341183 in forum AutoLISP
    Last Post: 2012-11-14, 10:33 PM
  3. Replies: 9
    Last Post: 2012-01-21, 07:58 AM
  4. LISP Debug Broken - Need Lisp to VBA Convert Help
    By bsardeson in forum VBA/COM Interop
    Last Post: 2010-10-06, 05:37 PM
  5. New Plot Device - LISP Routine
    By techsupport.161645 in forum AutoLISP
    Last Post: 2009-01-09, 09:55 PM
