Results 1 to 10 of 10
Thread: Some TIFF's not showing as transparent in PDF
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Default Some TIFF's not showing as transparent in PDF
    Howdy y'all,
    Funny how the really important problems pop up just before a deadline.
    I've got a group of drawings that I'm using scanned tiffs as the basis of an existing site and building, with solid hatches to highlight areas. I've got he tiffs set to transparent. They show fine in ACAD and in print preview, but in the final PDF files, the tiffs aren't see-through and hide the hatch. Any ideas?
    100 Club The VLG's Avatar
    2005-04
    on the up....
    137
    Default Re: Some TIFF's not showing as transparent in PDF
    Have you tried DWfing them first? that was the work around to my pdfing with wipeouts problem
    1,324
    Quote Originally Posted by VLG
    another problem I'm having is that the printers in ACAD are shfting the tiffs when I use them. Everything shows fine on preview. the DWF printer does the same thing.
    AUGI Director scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    Doug:
    What PDF engine and version are you using?
    Do you lhave lines overwrite/lines merge control in your PDF engine?
    Is there an example you can post?
    Scott
    Turlock, CA
    6,379
    Also check the tiff type. Grayscale won't be transparent, since every pixel is shaded. Only bitonal images can be transparent.
    C:> ED WORKING....
    AUGI Addict Railrose's Avatar
    Abilene, TX
    1,181
    Check to make sure that on draworder, the image is on the back. Also, a problem I ran into a while back (ended up calling autodesk) is on CAD options, go to the plot publish tab. Try deselecting the box "enable background plot" - "plotting".
    Give people a job worth doing, the tools to do it, recognition of a job well done & get out of the way.
    1,324
    Quote Originally Posted by Ed Jobe
    done. no grayscale
    1,324
    Quote Originally Posted by drafter29
    both are true here
    Active Member jaffarhu's Avatar
    2005-08
    Bacau, Romania
    58
    send the TIFFs to back or vectorize the tiff`s content...
    You could also try changing the PDF exporter...
    I could stop if I wanted to Doodlemusmaximus's Avatar
    2005-04
    RAT HALL
    298
    We had this problem with images and wipeouts and the way we solved it is to write them to a eps file then us adobe distiller to create the files. Abit long winded I know but it worked.
  1. 2013: Ducts showing the linked arch model behind them as if they were transparent
    By jcolombe536338 in forum Revit MEP - General
    Last Post: 2014-03-02, 09:02 PM
  2. 2014: Issue with opaque text showing transparent???
    By joffutt317377 in forum Revit Architecture - General
    Last Post: 2014-02-25, 01:51 PM
  3. Replies: 3
    Last Post: 2006-12-14, 08:12 PM
  4. Filled Region not Showing Plan when Transparent
    By artitech in forum Revit Architecture - General
    Last Post: 2005-11-02, 11:59 AM
  5. Walls Showing Transparent when not intended
    By jamesd10181097 in forum Revit Architecture - General
    Last Post: 2005-03-25, 03:23 PM
