Thread: Sheet Set Manger - Refresh problem with AutoCAD 2007
    2004-08
    4
    Default Sheet Set Manger - Refresh problem with AutoCAD 2007
    SSM contains 150dwgs - is it too many? When I tried to use SSM, at each step whatever I do ACAD is not responding for 5~10 sec. If I close SSM, it's not halted . When I click the refresh icon in SSM, it takes same amount of time(5~10 sec), so I assume it keeps refreshing every minute. I didn't have this problem w/ 2005.
    Can I turn off that automatic refreshing function? or delay the frequency? Or just I got too many files? TIA.
    Earth
    9,804
    Default Re: Sheet Set Manger - Refresh problem with AutoCAD 2007
    Recently saw a similar issue here. Use Process Monitor to see what is happening in the background for those 5~10 seconds.
    In our case, AutoCAD was traversing other .dst files, and many different paths out on our network due to the way certain fields were linked. All this searching for, and retrieving of, this data took many seconds.
    Even hovering over a sheet caused a delay.
    R.K. McSwain | CAD Panacea |
  1. Sheet Set Manger Custom Properties
    Last Post: 2014-11-09, 03:17 PM
  2. Project organization by sheet set manger
    By e.mounir in forum AutoCAD Sheet Set Manager
    Last Post: 2008-09-23, 05:28 PM
  3. Profile and sheet set manger load on startup
    By dalewww in forum AutoCAD General
    Last Post: 2007-04-09, 09:11 PM
  4. Sheet Set Manger
    By CCR in forum AutoCAD LT - General
    Last Post: 2005-07-15, 11:40 PM
