greg.mcdowell
I'm a little fuzzy on what you're wanting to do exactly but it sounds like you want to get a computed value from a schedule into a tag... close?
Since you can't do this directly you'll need a small workaround. Create an additional shared parameter for your tag and add this to your schedule adjacent to the computed value then, from the schedule, manually type in the results from the computed column into this new column.
It's far from ideal but it's the only way to do what I think you want to do. We're doing similar things with Area Plans for code analysis (the basis of which was taken from several other posts on this subject) and we create schedules just for this purpose (i.e., we don't plan on putting them in the documents). Working well so far.
