I am looking for some help on getting an AutoCAD dwg file link to show up in all of the model views in Revit- specifically in plan view where I actually need to see it. Right now it only shows up in a 3D view and the remainder of the model is not visible, which seems a bit suspect, like the link is way off in Revit space somewhere but I can't locate the rest of the model at all even when I try and ZOOM TO FIT.
Here is what I have done so far:
Imported the drawing file as a link in the ground plan view (as a link, B/W lines & origin to origin), but it's not visible so I checked the following:
1. Visibility for imported categories in this particular view, and the link is shown as checked despite it not being visible
2. In Manage Links I made sure that the CAD format file is loaded and it is, but its not visible in plan view
3. I checked the view range and it is okay - in fact when I turn on other CAD DWG links they show up just fine.
4. I checked the origin point in the Autocad file and it appears to be sinced up with the revit file, but when I try and import the file I get the following warning:
"Imported objects located a large distance from the model might not display properly. The 'Center-to-Center' option will be used."
Can anyone help me out with this?
