Thread: How to find the length from the start point of a polyline?
    Active Member pferreira's Avatar
    2006-06
    Lisbon, Portugal
    88
    Default How to find the length from the start point of a polyline?
    You can find the length from the start point of a polyline without breaking it by using this vlisp expression (vlax-curve-getDistAtPoint (vlax-ename->vla-object (car (entsel))) (getpoint "\nSelect point: \n")), with this it will ask you to select an object and then it will ask you to select a point along the polyline, finally it will return the distance from the start point (vertex 1).
    Best Regards
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: How to find the length from the start point of a polyline?
    But if you miss the object this would error out. You would need to make sure an item is selected. You will also need to verify that it could have a length.
    Other than that, it looks good.
  1. Total polyline length
    By jbenway in forum AutoCAD General
    Last Post: 2011-10-18, 06:08 AM
  2. polyline length macro
    By brett.warren in forum AutoCAD LT - General
    Last Post: 2010-02-18, 03:46 PM
  3. Replies: 9
    Last Post: 2007-02-21, 10:43 PM
  4. Attribute polyline length
    By santoshkumar.bs in forum AutoLISP
    Last Post: 2005-12-09, 12:01 PM
  5. C# - closed Polyline length
    By RoSiNiNo in forum ARX
    Last Post: 2005-03-02, 03:17 PM
