Results 1 to 6 of 6
Thread: Best way to document Client and Company CAD Standards
    100 Club avdesign's Avatar
    2005-08
    STL Metro
    173
    Default Best way to document Client and Company CAD Standards
    I'm a one man operation, but I'm in the process of adding another body to keep up with the demand. So I need to document all my standards and my clients standards for my new employee. I have some non formal templates and so on, but I need to make everything as bullet-proof possible so I can focus on other things and not micro managing. Any good ideas with respects to Font types, Plotting, Dims, Layers, and anything else.
    AUGI Addict Augi Doggie's Avatar
    2002-01
    Orlando, FL.
    1,348
    Default Re: Best way to document Client and Company CAD Standards
    Quote Originally Posted by avdesign
    Well, you're in the right forum. I would suggest browsing through this forum and looking at specific topics in here, there are quite a few good discussions on the topic.
    Honestly, standards vary a lot depending on the industry you are in. I would suggest checking out the National CAD standard. Also helpful for Civil is the AEC standard.
    Hope that helps.
    2002-09
    Madison, WI
    5,687
    If you are going to look at the NCS, I'd suggest you only use the basic parts of it, or only the ones that make sense. Having different sets of layers for plans and details is not a bad idea, but creating another set for elevations and sections is just a little over the top IMHO.
    2002-01
    Orlando, FL.
    1,348
    Quote Originally Posted by david_peterson
    That's something I hear a lot, and I agree with the comments.
    The NCS can be overwhelming, just take from it what you need, don't over-complicate things.
    2002-09
    Madison, WI
    5,687
    The bigger issue with the NCS is that once someone adopts it, they don't want to change it, yet the NCS continues to be updated/modified. So basically even though you are on the NCS, you may not be on the correct version of NCS. I think they should really call it the NSNCS or the Non-Standard National Cad Standard.
    2005-06
    in the upper right corner
    3,507
    Cool Re: Best way to document Client and Company CAD Standards
    I'm going to pile on too...
    I agree with all of you, it really doesn't need to be as complicated as it is.
    We still work mostly in the 2-D world and the difference between the A-SECT and A-DETL layers works good for us in doing building and wall sections.
    We do a whole building section using the A-SECT layers and do the finer details in the same drawing using the A-DETL layers as needed. When used as an xref we simply freeze all the A-DETL layers for the building section sheets, and use the same base for the enlarged wall sections showing all the detail.
    We (mostly) use the NCS too, because we do allot of work for the dod, gsa, coastgurad, etc. and they all reqire some version of the NCS.
    The version of NCS (and attention to the standard) depends on which one you're working for.
    I believe the Coast Guard is using NCS 3.1 now which is the one we have in house. I've seen some of our other clients refering to an older version.
    Ted
  1. CM31-1: Help! I Have to Use the Client's CAD Standards
    By Autodesk University in forum CAD Management
    Last Post: 2012-11-24, 07:38 PM
  2. MG33-2: Help! I Have to Use a Client's Standards How to Protect Yourself
    Last Post: 2012-11-19, 03:44 PM
  3. Integrating Revit Help and company BIM Standards
    By Rustle in forum Revit Architecture - General
    Last Post: 2010-01-08, 06:41 PM
  4. Replies: 4
    Last Post: 2006-03-22, 12:23 AM
  5. Personalized settings and company standards
    Last Post: 2005-10-28, 02:22 PM
