Results 1 to 9 of 9
Thread: Change text case in an entire table at the same time
    I could stop if I wanted to mom of 3's Avatar
    2004-07
    jUSt in the middle
    366
    Question Change text case in an entire table at the same time
    Is there anyway to change the text case in an entire table at the same time or do I have to do each cell separately? This is my first time using tables, & the one that I'm modifying was created by someone who no longer works here...........
    ACAD 2006 with LDD 2006
    2001-12
    St. Louis
    5,313
    Question Re: Change text case in an entire table at the same time
    hmm, i've never tried this but looking \/ down there under similar threads, you're getting hits in two wishlists, so I'm going to assume not... ~fingers crossed that assumption is wrong~
    Quote Originally Posted by wrestlemom
    ..........but - is there anyway to change the text case in an entire table at the same time or do I have to do each cell separately? This is my first time using tables, & the one that I'm modifying was created by someone who no longer works here...........
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use Revit and Tririga, too)
    Technical Editor
    150700
    3,434
    Default Re: Change text case in an entire table at the same time
    You can do a search and replace, but I'm not sure how that could help you - I suppose you could do a search and replace by letters
    2004-07
    jUSt in the middle
    366
    I don't think this has to do with editing text, though because aren't the tables supposed to be like excel OLE objects? I'd searched for editing tables before I posted, couldn't find anything - but what do I know? *shrug*
    Thanks!
    2005-01
    185
    There are many LSIP routines for changing the case of text, they have worked just fine for me on tables, in some cases you may ned to modify them to recognise tbales, but tables are fancy versions of Mtext, not OLE objects. The routine that I use was wrttin in the early 90s and still works the best of any of te ones I have found.
    2004-07
    jUSt in the middle
    366
    I guess I need to restate my question - I was asking about changing case on the table cells all at one time like attributes as opposed to one cell at a time. I thought I had asked that in the first post, but I guess not. I understand that it is possible to change case on text & mtext, I was trying to find out about tables.
    150700
    3,434
    No, AFAIK, it is not possible. As I stated above, you can use the find and replace feature in AutoCAD to replace the words in your table (I'm not sure if that will be quicker than opening each cell to edit it).
    2004-07
    jUSt in the middle
    366
    Drat - find & replace would take longer. None of the cells have the same wording. Oh well. Thanks!
    150700
    3,434
    You could run it 26 times, replacing it letter by letter - that might be quicker, depending on how big your table is ~shrug~
  1. MTEXT Change Case deletes selected text
    By Darren Allen in forum Land Desktop - General
    Last Post: 2014-07-09, 06:00 PM
  2. Change text case tool
    Last Post: 2009-11-03, 03:16 PM
  3. Preview mode for Change Text Case
    Last Post: 2008-05-14, 07:04 PM
  4. How to change case in text?
    By david@stearnsarchitecture in forum Revit Architecture - General
    Last Post: 2006-10-31, 03:42 PM
  5. Change text case
    By patricia.ellistone in forum AutoCAD Wish List
    Last Post: 2005-06-13, 05:37 PM
