Thread: ADT 2005 to AutoCAD 2007 back to ADT 2005
    2000-06
    159
    Default ADT 2005 to AutoCAD 2007 back to ADT 2005
    We have a client that created dwg's in ADT 2005, we have done work on them in AutoCAD 2007.
    We are saving back as 2000 dwg format, because they have ADT 2005.
    When they open the files they keep getting "arx error" messages, one after the other.
    We have tried loading some enablers but that doesn't seem to help.
    any ides?
    mahalo...
    aloha...yoshi
    All AUGI, all the time cadkiller's Avatar
    2003-09
    Bergenfield, NJ
    694
    Default Re: ADT 2005 to AutoCAD 2007 back to ADT 2005
    Why not try to save as 2004 format?
    2003-03
    Philadelphia, PA
    2,371
    AutoCAD 2007 has the object enabler for ADT 2007 objects built into it. When you opened the file, the 2004 format ADT objects were promoted to ADT 2007 objects. You can not save that file back to 2000 or to 2004 and have the usable ADT objects. The effect is the same as if you had opened the file in ADT 2007.
    You could Export to AutoCAD 2004 format, but the result would be an exploded drawing with no ADT objects, which I doubt is the desired result.
    David Koch
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,722
    Hey Yoshi! Good to see you online! They can also download and install the object enablers from Autodesks website to allow them to view the objects from 2007 - they just wont be able to edit them.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
  1. points ing 2007 back to 2005
    By eleonard in forum Land Desktop - General
    Last Post: 2007-01-22, 05:53 AM
  2. AutoCAD 2007 to 2005 - ARX_ERROR: eNotThatKindOfClass
    By droach in forum AutoCAD General
    Last Post: 2006-10-19, 06:39 AM
  3. TEMPLATE in AutoCAD 2007, but 2005 cannot read it
    By djahnke in forum AutoCAD General
    Last Post: 2006-09-21, 09:24 PM
  4. 2005 to 2007 to 2005 problems
    By dandan_2 in forum ACA General
    Last Post: 2006-05-12, 12:49 PM
  5. Importing MD 2005 2D fastener library parts into AutoCAD 2005
    By garyp.97584 in forum AutoCAD General
    Last Post: 2005-10-18, 09:43 PM
