Results 1 to 6 of 6
Thread: AutoCAD 2005 - REFCLOSE won't save as default version
    2004-05
    11
    Default AutoCAD 2005 - REFCLOSE won't save as default version
    When saving an edited xref using the REFCLOSE command, AutoCAD 2005 saves in the 2005 drawing format, not the default format specified in the Options dialog box. Is there a workaround for this?
    150700
    3,439
    Default Re: AutoCAD 2005 - REFCLOSE won't save as default version
    I moved this post the 2005 general forum, as it seems you are asking a question. If you indeed find that a work around is not possible, and this is truly not a feature in 2005, please feel free to repost in the wish list forum in the form of a wish for the next new version
    Thanks
    2002-02
    St. Louis, MO
    4,695
    Nope. Only option is to convert the files back later. Not good for those that need to work in a mixed version enviornment.
    2001-12
    St. Louis
    5,407
    this problem also occurs when doing a batch save via the sheet set.
    I learned that one the hard way.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2001-07
    29
    i save everything in r2005 and when i need to save drawings to a previous release i copy the dwg files to a temp folder and batch convert them down, then delete from the temp folder
    i do this in an effort not to overwrite my 2005 files, so far so good
    nick
    2001-12
    St. Louis
    5,407
    Talking Re: AutoCAD 2005 - REFCLOSE won't save as default version
    yeah, well, lets just say someone could pre-release test a software package, and so need to have everything saved back down to be read by their production version. And it could be months after the uninstall of said beta software that there was a purchase of software which could read the aformentioned files.
    Now that I actually own the final product, I do as you do with the separate folder.
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. What default DWG format does AutoCAD 2009 Save in?
    By Capt. Computer Crasher in forum AutoCAD General
    Last Post: 2008-05-02, 11:07 AM
  2. What format does AutoCAD 2006 save as, as default...
    By howardnw in forum AutoCAD General
    Last Post: 2006-06-29, 07:40 PM
  3. Replies: 4
    Last Post: 2006-02-25, 10:34 PM
  4. AutoCAD 2005 - Copy no longer multiple by default?
    By VirtualBuilding in forum AutoCAD General
    Last Post: 2006-02-07, 09:20 PM
  5. AutoCAD 2005 set Copy command to single default option
    By john.forman in forum AutoCAD General
    Last Post: 2004-10-12, 04:03 PM
