Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Update a Field using a visibility state in a Block
    2005-05
    111
    Question Update a Field using a visibility state in a Block
    Question????
    I have a door block in a drawing that is in a unit block with 2 visibility states. When I add a door call out to the door it will pick up the door info. But if I update the door info the block door call out will not update. But if I delete the visibility state form the unit block the door tag will update.
    How can I get the door call out to update if I add a visibility state to my unit block.
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Update a Field using a visibility state in a Block
    please forgive me, but i'm still a little confused by your problem description and block relationships. first, is the door block itself a Dynamic Block? (sorry, but i'm at a loss as to what a 'unit block' is refering to) and what version of cad are you using?
    S&D DB Sharing Forum
    2005-05
    111
    Yes the Door is an Dynamic Block. And the door is nested in a Dynamic Block with other objects.
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by pangell
    if i understand you correctly, you should not be nesting DB's. that may be why you are having issues. the removal of the 'vis state' (if that's the only Dynamic property you have in the tag) makes it a normal block
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    maybe it has something to do with the fact that it is nested?
    I don't think it works that way ......... am i wrong, Chris?
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,483
    Is the field in an ATTRIBUTE object or in a TEXT/MTEXT object? FIELDs do not update in TEXT/MTEXT objects within blocks.
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by max.sabre
    hehehe GMTA. (and one minute apart apparently!)
    2005-06
    1,828
    Quote Originally Posted by Chris.N
    Yeah, you have to regen to update a field, but if the block is nested, then it doesn't react the same way as the other blocks ....
    deleting a vis state and making it a regular kind of defeats the purpose of Dbs, doesn't it? You go to all the trouble only to delete a vis state?
    [SIGPIC][/SIGPIC]
    2005-05
    111
    The visibility state is the only Dynamic item in the block. So that is it. But why can the callout not pick up the property set info with Dynamic info in the block. There must ba a way to do it.
    2001-12
    Rochester, MN
    2,561
    ok, let's eliminate some assumptions. can you please post your file for additional comment? (2006 please)
  1. Select a block's visibility state via LISP
    Last Post: 2013-11-15, 01:38 PM
  2. Visibility state when inserting a Dynamic Block
    Last Post: 2012-06-13, 01:10 PM
  3. Visibility State selection upon insert of block?
    By Mamma Jamma in forum Dynamic Blocks - Technical
    Last Post: 2010-09-01, 11:41 AM
  4. Changing a visibility state for a Dynamic Block
    By jahed.ali in forum AutoLISP
    Last Post: 2010-06-04, 05:28 AM
  5. Creating a Field from a Visibility State
    By Alistair0610 in forum AutoCAD Fields
    Last Post: 2006-11-17, 12:43 PM
