Thread: Can't get attribute to rotate in dynamic block
    2005-12
    Hartford, CT
    394
    Default Can't get attribute to rotate in dynamic block
    I am trying to create a dynamic block for a doortag. One of the action I want the block to do is rotate. But when I create the rotation parameter and select the objects I want to rotate (attribute & the tage outline) I get the following message "1 unlock AttDef filtered from selection".
    Basically AutoCAD will not allow me to add the attribute to the rotation set. Any ideas?
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Can't get attribute to rotate in dynamic block
    Quote Originally Posted by tim.101799
    check the 'lock location' property for the attribute
    S&D DB Sharing Forum
    2005-12
    Hartford, CT
    394
    Quote Originally Posted by Chris.N
    It was set to 'no" I changed it to 'yes' and everything works fine now. Thanks.
  1. How to change dynamic block attribute default values based on block selected?
    By zeirz109180 in forum Dynamic Blocks - Technical
    Last Post: 2013-12-13, 02:20 PM
  2. How to best rotate/flip symbol with block attribute
    By kknauss in forum Dynamic Blocks - Technical
    Last Post: 2013-11-11, 01:28 PM
  3. 2012: Rotate Attribute in a Dynamic Block
    By KansasCAD in forum Dynamic Blocks - Technical
    Last Post: 2013-03-13, 06:38 PM
  4. Rotate block not attribute within
    By fletch97 in forum Dynamic Blocks - Technical
    Last Post: 2009-02-06, 08:56 PM
  5. Dynamic block attribute rotate
    By csf in forum Dynamic Blocks - Technical
    Last Post: 2008-07-08, 03:56 PM
