Thread: Palette Path - Toolbar Code to change path
    2005-03
    5
    Default Palette Path - Toolbar Code to change path
    Relying on Tool Palettes more and more to maintain Standards and increase productivity. We have too many palettes to load at one time so I am creating palettes in various folders. Should be able to select a Palette Path with a Toolbar Button. Any ideas?
    2001-12
    St. Louis
    5,406
    Question Re: Palette Path - Toolbar Code to change path
    I don't really know, but, I see this thread Change The enterprise cui path with VBA down in the 'similar threads' section below... could it help you?
    Quote Originally Posted by kenb
    Melanie Stone
    @MistresDorkness
    Technical Editor
    I could stop if I wanted to johan d's Avatar
    2006-01
    Belgium
    287
    Default Re: Palette Path - Toolbar Code to change path
    13,656
    Hi "kenb" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the CAD Standards forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    13,656
    Hi
    For starters...
    RE: Tool Palette access from a command or button?
    Have a good one, Mike
  1. Diesel code for adding drawing path to RText
    By ted.evans in forum AutoCAD General
    Last Post: 2009-11-12, 01:00 PM
  2. Change Xref from Full Path to Relative Path
    By ccowgill in forum AutoLISP
    Last Post: 2009-05-27, 11:54 AM
  3. Change tool palette path?
    By randyspear in forum AutoCAD General
    Last Post: 2008-05-23, 03:07 PM
  4. AutoCAD 2006 extrude along a path - Profile and path are tangential.
    By judekw in forum AutoCAD 3D (2006 or below)
    Last Post: 2007-05-24, 07:48 PM
  5. Change Tool Palette path via VBA
    By mboyer in forum VBA/COM Interop
    Last Post: 2007-02-21, 01:46 PM
