Thread: Stretch where the distance of change is split evenly between two doors/drawers?
    Member schmitzrd's Avatar
    2006-04
    South Central PA
    5
    Cool Stretch where the distance of change is split evenly between two doors/drawers?
    Question:
    I have some base & wall cabinet blocks that are two doors/drawers wide. Can I set up a stretch where the distance of change is split evenly between the two doors/drawers? Thanks
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Default Re: Stretch where the distance of change is split evenly between two doors/drawers?
    Quote Originally Posted by schmitzrd
    Question:
    check the dynamic block sharing thread, we have the exact thing you're looking for. (it's in the Dynamic Blocks Forum.)
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    13,656
    Hi "schmitzrd" ( Sorry, I do not know your real name )
    Please note I have *split* your above post into its own thread ( from thread Dynamic Block Tips & Tricks (Techniques) ).
    Plus, I have *moved* this thread from the AutoCAD Tips & Tricks forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
  1. Change Max Distance of multiple blocks?
    By laneclare in forum AutoLISP
    Last Post: 2012-04-06, 02:19 PM
  2. problem with stretch doors DB
    By mateo in forum Dynamic Blocks - Technical
    Last Post: 2008-01-19, 04:41 AM
  3. How to change the distance of Arc?
    By whdjr in forum Dynamic Blocks - Technical
    Last Post: 2007-07-15, 07:11 AM
  4. Unable to Stretch a 3D wire frame using relative distance
    By awarren in forum AutoCAD General
    Last Post: 2006-12-07, 04:18 PM
  5. Stretch cabinet doors so they remain equal
    By david.scheu in forum Dynamic Blocks - Technical
    Last Post: 2006-09-25, 02:56 PM
