Results 1 to 10 of 14
Thread: Continuous back saving of a DWG can compromise the DWG integrity. Is that true?
    2005-11
    Daly City, Ca.
    41
    Default Can continuous back saving of a DWG compromise the its integrity?
    I heard that continuous backsaving of a file can compromise the file integrity of a drawing. Is this true? If so, is there any documentation out there that supports this and is there something that we can do to minimize or even prevent this from happening? It sounds like it can happen but its the first time that I've heard of the situation.
    Any input would be greatly appreciated. We are currently using 2006 and backsaving to 2000 file format. W/in a matter of days we'll be moving up to 2007 and will have to backsave those to 2000.
    Christian
    13,656
    Default Re: Continuous back saving of a DWG can compromise the DWG integrity. Is that true?
    Hi Christian
    Please note I have *moved* this thread from the Software forum to this one, as I believe it will be better served here.
    Thanks, Mike
    Forum Manager
    All AUGI, all the time Firmso's Avatar
    2006-03
    Here, Still
    549
    Quote Originally Posted by sumulong
    Christian
    I would think that anything that is backsaved consequently tends to compromise the integrity of it. But I don't think it would be so drastic as to loose some sleep over it though.
    2005-11
    Daly City, Ca.
    41
    Of course, I wouldn't expect that the fuctionality of dyn blocks or any new feature would work when backsaving. I guess i'm more worried about losing data/ content.
    0,0,0 The Origin
    8,570
    What do you mean by "continuous backsaving " ?
    Continually round-tripping between older and newer versions?
    Saving to an earlier version and keeping it in that version?
    Either way, you shouldn't have a major problem.
    All AUGI, all the time Richard McDonald's Avatar
    2002-01
    At right angles to reality
    537
    I know I have definitely have problems on previously releases and it looks like its still happening with 2007.
    http://forums.augi.com/showthread.ph...highlight=save
    Richard
    0,0,0 The Origin
    8,570
    Quote Originally Posted by McDonaldRi
    Richard
    Hi Richard.
    That thread refers to a specific problem and includes the answer -
    Quote Originally Posted by Wanderer
    as predicted... http://autodesk.blogs.com/between_th...ew_hot_fi.html
    the fix can be downloaded here...
    now... for $40, I will read your palm...
    I don't think it's the same question, though I'd still ike to know what "continuous backsaving " is supposed to mean.
    2002-01
    537
    I think Christian Is talking about saving down to a previous version of ACAD. setting this permanently in the options area? (let me know if I'm completely off track).
    At a few places I've worked at they have upgraded just one machine and I think every time it has corrupted drawings whilst saving down. Not everytime but often enough to be a problem. My opinion is you either upgrade all the machines in a company or none.
    The link was about a similar problem with 2007 and discussing the use of True Convert by Autodesk which is available free from their website.
    Richard
    0,0,0 The Origin
    8,570
    Richard
    The linked thread actually stated that True Convert would not solve that particular, A2007-specific problem.
    2002-01
    537
    Original Question - Continuous back saving of a DWG can compromise the DWG integrity. Is that true?
    Answer - Yes with an example the link.
    Try True Convert.
    Try the hot fix provided in the link.
    Best to keep a back up that is never saved down.
    Probably me not explaining myself properly.
    Richard
  1. 2013: Saving to DXF and Back to DWG
    By SparkyJ in forum AutoCAD General
    Last Post: 2013-10-25, 12:31 PM
  2. Saving back
    By darthyoga in forum AutoCAD General
    Last Post: 2009-05-27, 01:20 PM
  3. Batch Saving back to 2000
    By rhayes.99001 in forum ACA General
    Last Post: 2006-05-08, 02:21 PM
  4. Back / Front Clipping not saving
    By stusic in forum AutoCAD 3D (2006 or below)
    Last Post: 2005-11-04, 05:50 PM
