I'm a new user in inventor 7 and i'd like to know how to modify an existing workplane.
Hello,
One way to do that is to Re-define the plane.
What i usually do is make a construction sketch for the workplane. I dimension the sketch off another feature that does not move or change (if possible), The sketch is usually just one line. Then when i create the workplane i select that line and another existing plane to get the new work plane. I'll turn off the construction sketch so it's not in the way. If i ever need to change the offset or angle i just turn the visibility for the sketch back on and edit , change the dimension needed and the workplane stays with it.
Seems to work very good for me in controlling it's location, offset or angle, etc.
Anyhow, Hope this helps you.
Rich
