Thread: Detail Component Manager
    2005-05
    40
    Default Detail Component Manager
    When using the detail component manager, is there a way to select a different orientation for the components that you are bringing in? For example, when pulling in a steel shape, it brings the shape in as a section, rather than in elevation. When inserting the metal deck component it draws it in the orientation parallel with the metal deck, rather than in a perpendicular orientation to the metal deck.
    Is there a way to toggle between these different orientations with the detail component manager?
    Thanks in advance for any assistance.
    Ben Schwab
    2002-09
    Madison, WI
    5,687
    Default Re: Detail Component Manager
    Yes, look at the properties box before you place the item. There's a pull down that allows you to select section, plan or elevation for just about ever component in the library.
    You just can't toggle them after they've been placed.
    2005-07
    2,356
    Post Re: Detail Component Manager
    It depends how the ootb componants are setup, when you insert a steel column for example, if you have the properties palette open you can change between section, elevation and plan.
    Is this what you mean or have I misunderstood you?
  1. Detail Component Manager
    By rhayes.99001 in forum ACA General
    Last Post: 2013-10-21, 04:09 PM
  2. 2012: Where is my Detail Component Manager?
    By bridgettb685611 in forum ACA General
    Last Post: 2011-09-02, 04:52 PM
  3. Detail Component Manager
    By dave.163549 in forum ACA Wish List
    Last Post: 2010-03-11, 11:06 PM
  4. Detail Component Manager
    By ssmith.62044 in forum ACA General
    Last Post: 2008-12-03, 03:29 PM
  5. 3D Detail component manager
    By cadkiller in forum Revit Architecture - Wish List
    Last Post: 2005-01-04, 11:16 AM
