Results 1 to 8 of 8
Thread: Anybody know how to make seamless export to .dgn?
    2006-07
    Default Anybody know how to make seamless export to .dgn?
    My organization recently was absorbed by a GIANT Multinational, we need to have a seamless way to convert our dwg files to dgn, else we will lose this battle and have to switch platforms...can anybody help ?
    2001-12
    St. Louis
    5,412
    Cool Re: Anybody know how to make seamless export to .dgn?
    Quote Originally Posted by mknowler
    Autodesk MAP3d will export to DGN, or Microstation can read DGN itself. You didn't mention the program/release you're using or the release of MS being used, but, there is no way to do it in plain vanilla AutoCAD. I think there is some sort of DGN converter in the works at Adesk, but I don't know what all it does offhand.
    I haven't used any standalone convertors that may be available on the market right now, hopefully someone else can speak on them with authority.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Earth
    9,816
    Default Re: Anybody know how to make seamless export to .dgn?
    Forget it. There is no perfect method. The two formats each have properties and features that the other doesn't - which means something gets compromised in the translation.
    If your drawings only contained lines, arcs and text - you might be OK, but most of today's drawings are much more complex with blocks, objects, etc.
    The general consensus is to do the work in the required format.
    R.K. McSwain | CAD Panacea |
    2002-09
    Madison, WI
    5,688
    From what I've heard, Revit dose a decent job export to .dgn format. The other option that I've heard of is Navis Works, but again, I've only seen the export side. I don't have microstation so I can't tell you what comes in.
    Cairo - no, not Illinois
    5,070
    RK is right -- it's not possible to seamlessly translate between dwg and dgn. it's possible to get workable translations, if your level of compatibility is low enough, but they will not be exactly the same because a) the complex object are not the same objects, and b) not all the simple object have equivalents. a linestring is not exactly the same thing as a polyline, even though they are similar. a point in Acad translates to a zero-length line in the other place, and a circle translates to an equal-length ellipse. those are completely different mathematical descriptions.
    On the bright side, if the new boys are huge fans of the Bentley boys, then they can use the 'seemless' ability of Microstation to use AutoCAD drawings.
    Marketing hype aside, when I've needed to do this for client deliverables, I converted my working acad drawings to dumb acad drawings, with simple drawing objects, and translated those to the other side.
    13,656
    Quote Originally Posted by Wanderer
    <SNIP> I think there is some sort of DGN converter in the works at Adesk, but I don't know what all it does offhand.
    <SNIP>
    Hi
    Just for information purposes...
    DGN V8 translator now in Beta for ACAD 2007
    Have a good one, Mike
    2001-12
    St. Louis
    5,412
    Talking Re: Anybody know how to make seamless export to .dgn?
    Quote Originally Posted by Mike.Perry
    Hi
    Ah, there we are... my first mistake was searching the www instead of good old augi. Thank you!
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Earth
    9,816
    It's been on http://labs.autodesk.com for a few weeks. Not sure where you searched on www ....
    No matter the tool, they all suffer from the facts posted above...
  1. Seamless Brick
    By dzatto in forum Revit Architecture - General
    Last Post: 2010-06-22, 02:12 PM
  2. Seamless plaster line for wall-column joint?
    By sumedha2512 in forum Revit Architecture - General
    Last Post: 2009-11-24, 08:46 PM
  3. Seamless Roof/Wall Join
    By bregnier in forum Revit Architecture - General
    Last Post: 2009-11-04, 08:33 PM
  4. Seamless tiling
    By charliep in forum Revit - Rendering
    Last Post: 2008-02-29, 04:21 PM
  5. Import of Seamless Data Distribution
    By whittendesigns in forum AutoCAD Map 3D - General
    Last Post: 2007-01-12, 02:39 AM
