Results 1 to 10 of 20
Thread: Unable to delete unwanted Objects from a drawing
    Member abertigger's Avatar
    2006-07
    Between hell and a hand basket
    48
    Default Unable to delete unwanted Objects from a drawing
    I have a drawing that has loads of little lines on it, that I am unable to delete. I have tried deleting the layer they are on, but it says I can't delete as there are things on the layer. I have also tried to purge, but that hasn't worked either.
    Any suggestions?
    0,0,0 The Origin
    8,569
    Default Re: Unable to delete unwanted Objects from a drawing
    Can you select the lines but not delete them or can you not select the lines at all?
    John B
    I could stop if I wanted to Doodlemusmaximus's Avatar
    2005-04
    RAT HALL
    298
    You could try making that layer current and freezing the rest then delete all. Hopefully that will remove them. If not check whether the layer is locked or if they are asscociated with a block.
    CAD RAT AKA Mr dribble, AKA Grumpy Old Man.
    2006-07
    48
    jaberwok - you can't select the items , or delete them
    beldin - I have tried to freeze the other layers and delete, but that didn't work, any other suggestions?
    2005-04
    RAT HALL
    298
    can you post a copy of the drawing, sounds like a mystery to me.
    0,0,0 The Origin
    8,569
    If the lines are on only one or two layers and there is nothing else on those layers, freeze those layers and Wblock the entire drawing to a new file by windowing the entire drawing. There is a risk of losing things that you want to keep so select carefully.
    John B
    2006-07
    48
    that seems to have worked, thanks!!
    2005-04
    RAT HALL
    298
    There is still the reason why it didn't happen i the first place I guess. If you could post the drawing anyway I'd love to try to track it down just for my own peice of mind
    2006-07
    48
    I have attached the drawing, happy problem solving!!
    2005-04
    RAT HALL
    298
    Quote Originally Posted by abertigger
    CHEERS FOIR THAT
  1. 2012: Unable to delete objects
    By J. Grouchy in forum ACA General
    Last Post: 2012-08-31, 03:49 PM
  2. Unwanted objects in view
    By mrdavie in forum Revit Architecture - General
    Last Post: 2010-08-26, 08:45 PM
  3. Unable to Delete Layers from drawing file
    By slade.87987 in forum AutoCAD LT - General
    Last Post: 2008-04-30, 02:33 PM
  4. Drawing area seems too large, unable to see Objects I should
    By neilcheshire in forum AutoCAD LT - General
    Last Post: 2006-09-22, 07:39 AM
  5. Unable to select OLE (eg Excel) Objects within drawing file
    By Mike.Perry in forum AutoCAD FAQ (Read only)
    Last Post: 2005-03-26, 07:05 PM
