Thread: diffusers upside down
    I could stop if I wanted to dmb.100468's Avatar
    2005-11
    Virginia
    222
    Default diffusers upside down
    Why are my diffusers coming in upside down? I am trying to use the Square Supply Diffuser - Hosted family in a Mechanical Ceiling plan. When I place the diffuser it comes in upside down on the floor. I have to go to the floor plan, select it, change it's properties to give it an elevation, but it is still upside down. Is it because I'm an electrical guy dabbling in the world of ductwork and air supply???
    I could stop if I wanted to roy.70844's Avatar
    2004-06
    South Wales UK
    278
    Default Re: diffusers upside down
    Nope, can't get it to fail. I'm using revit building 9. When I place the square diffuser it sets it's self to the ceiling level. My familiy is also 2D only so I can't tell if it's upside down or not!
    Roy
    2005-11
    Virginia
    222
    I worked it out with Autodesk on their website forum. Turns out the family is upside down.
    2006-07
    4
    FYI - for the benefit of others who may view this post:
    The hosted diffuser families are defined to appear "right-side-up" only when placed on a ceiling, or on a work plane associated with a ceiling.
    The hosted diffusers are defined upside down in the family editor because of the way ceilings currently work as hosts. When a hosted family is placed in a ceiling, it is "flipped" 180 degrees, which causes the "upside down" hosted diffuser families to be created "right-side-up" when placed on a ceiling in the project. When these "upside-down' diffuser families are placed on any surface/work plane that is not associated with a ceiling, then they will not be flipped, and thus will appear upside-down in the project.
    The Revit Systems team is aware of the confusion and potential problems this could cause and is working on improvements for future releases.
    Jason Bishop
    Autodesk
    Revit Systems QA
  1. Duct mounted grilles & diffusers
    By DaveDH in forum Revit MEP - General
    Last Post: 2012-03-27, 07:08 PM
  2. Round Diffusers
    By RCA4697 in forum Revit MEP - General
    Last Post: 2010-03-01, 08:42 PM
  3. Duct Mounted Diffusers
    By cwade.109269 in forum Revit MEP - General
    Last Post: 2009-04-01, 04:16 AM
  4. Diffusers not plotting
    By Kirk Bricker in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-03-10, 08:09 PM
  5. Diffusers Not Snapping
    By phil.pleiss in forum Revit MEP - General
    Last Post: 2008-06-04, 02:48 PM
