msanders.85217
Hi,Please help. I'm going crazy. I have read several posts here talking about the insunits/insunitsdefsource/insunitsdeftarget/ etc. being all set to 0 variable. Well, I have a block that I'm trying to insert into 2 different dwgs. In one, it comes in at the right scale, no need to adjust. The other dwg, no such luck. The block comes in much larger (actually twice the size). Both drawings have the same dimscale, same settings as far as insunits, insunitsdefsource, etc. which are all set to 0. so, if both drawings have the same settings, what is causing this scale problem in one? I have tried all of these settings as far as I'm reading on your website. There must be yet another problem or variable not set right? This happens just some of the time, particulary when I'm placing the block (my title block is what it is) into a drawing received by a client or some other person. Please help, going crazy over here! Thanks so much for any help.
