Results 1 to 7 of 7
Thread: Layer search upon each drawing OPEN
    2003-10
    706
    Default Layer search upon each drawing OPEN
    Is there a niffty way to search a drawing for a specific layer upon opening a drawing and determine whether or not the layer is OFF/ON or FROZEN/THAWED? I've done the table search thing for "LAYERS" but the layer I want will always be embedded inside of an xref so it's impossible to know what the prefix of the layer name will be. I've tried wildcards in the "LAYER NAME" portion but they didn't work... at least the way I used them. Any suggestions?
    All AUGI, all the time Avatart's Avatar
    2004-06
    Upsidedown in dreamtown
    927
    Default Re: Layer search upon each drawing OPEN
    To do this automatically, you would need some sort of reactor. Personally I am not too keen on reactors, if you getthem worng they can make one hell of a mess of you drawings.
    What have you done re wildcard searching the layer table?
    ^^ Ceci n'est pas une post ^^
    2005-08
    1,043
    If you want to check upon opening a drawing, you just need to have the routine autoload, and run it. You can have it autoload serval different ways. If the layer if going to be in a xref ALWAYS, then maybe something like
    (defun LayExist (LayName)
    (vl-catch-all-error-p
     (vl-catch-all-apply
      '(lambda ()
       (vlax-for Lay (vla-get-Layers (vla-get-ActiveDocument (vlax-get-Acad-Object)))
        (if (wcmatch (strcase (vla-get-Name Lay)) (strcase (strcat "*|" LayName)))
         (exit)
    Edit: Didn't see the other part.
     (vl-catch-all-apply
      '(lambda ()
          (progn
           (prompt (strcat "\n Layer on status = " (vl-princ-to-string (vla-get-LayerOn Lay))))
           (prompt (strcat "\n Layer froze status = " (vl-princ-to-string (vla-get-Freeze Lay))))
           (exit)
    2003-10
    706
    I'll have the Lisp code automatically load from my own acad.lsp file so that's not a problem. I'm kinda old school when it comes to AutoLisp so I'm not familiar with the whole VisualLisp syntax. I'm using the old "tblsearch" code to search the dictionaries. See below. Then I'll go through the dotted pairs to list the status of each. The problem I'm having is the Xref name changing every time. Does anyone have an "old school" suggestion?
    (setq wmlayer (tblsearch "layer" "watermark"))
    The problem here is that the text "watermark" will always have the xref name in front of it.
    2004-06
    927
    You could scroll through the layer table and apply a conditional test, if "true" return a value, a bit like:
    (setq laynam (tblnext "layer"))
      (wcmatch (cdr (assoc 2 laynam)) "*|watermark*")
    The "*|watermark*" should find a layer called watermark on an xref layer. You would have to scroll this through the whole layer table obviously.
    2003-10
    706
    So the * (star) is a valid wildcard within the code? I tried using this in the tblsearch code and it just kicks it out with an error.
    Central Oregon
    591
    The star is valid when used with (wcmatch). It is NOT valid when using (tblsearch)
  1. Auto-Search Function in Open Dialogue
    Last Post: 2012-12-15, 05:56 PM
  2. Replies: 2
    Last Post: 2006-05-10, 06:38 PM
  3. Replies: 8
    Last Post: 2006-05-01, 06:39 PM
  4. Open sheet set manager without a drawing open
    Last Post: 2006-01-15, 05:30 AM
  5. Layer Manager & Layer drop down are slow to open.
    By Glenn Pope in forum AutoCAD FAQ (Read only)
    Last Post: 2005-03-17, 06:01 PM
