Hello AUGI Members:
I am relatively new to visual basic for applications and have a simple VBA batch plotting routine I developed to plot in-house drawings. The program works fine for our needs except when someone has a drawing or two open that I am trying to batch plot. When this occurs the routine stops and waits for you to answer the prompt to open the drawing as Read Only.
I basically want to know if there is a way to eliminate this from happening so the batch plot will run in an uninterrupted manner....??
I also have a another question about closing drawing files using the same VBA program. I am using the following line of code to close each drawing file:
###Code Start
ThisDrawing.Application.ActiveDocument.Close
It does close the drawing but it also saves the file and I really want to close the drawing file without saving it. Is there any way to accomplish this....??
Any suggestions or recommendations would be appreciated....!!
Regards,
Vince
