Results 1 to 10 of 12
Thread: I'm trying to create a linetype that has 8" in the linetype
    2006-08
    Default I'm trying to create a linetype that has 8" in the linetype
    what is the "control code" for the " symbol? I'm trying to create a linetype that has (8") in the linetype, and the syntax won't accept the (" symbol) in the text string
    All AUGI, all the time thomas.stright's Avatar
    2015-12
    Texas
    559
    Default Re: I'm trying to create a linetype that has 8" in the linetype
    Quote Originally Posted by mikeprentiss
    I believe that depends on the font being used.
    2001-12
    St. Louis
    5,406
    Question Re: I'm trying to create a linetype that has 8" in the linetype
    I'm going to move this from Local User Group forum to this one, as I believe it will be better served here. Thanks.
    Thanks.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Earth
    9,803
    This one doesn't come up very often - but I gotcha covered....
    See http://rkmcswain.blogspot.com/2005/0...linetypes.html
    R.K. McSwain | CAD Panacea |
    13,656
    Hi
    Or alternatively you could use information presented here in the AUGI forums...
    How to add " (inch) or ' (foot) characters to a linetype definition
    Have a good one, Mike
    Earth
    9,803
    Quote Originally Posted by Mike.Perry
    LOL...
    Yea, but mine was posted first (april vs. july)
    King of the augi search....
    13,656
    Quote Originally Posted by rkmcswain
    LOL...
    Hi
    Ok! If you want to play that game, check out the Published Date on the Autodesk Knowledge Base Technical Document referenced in the thread I linked to, above ( actual post containing ID: TS7318 )...
    Quote Originally Posted by Including special characters in complex linetypes
    Published date: 2000-03-07
    Earth
    9,803
    LOL... Your "alternative information presented here in the AUGI forums" was the exact same solution - I didn't see the point.
    BTW: Here is a tip for you. To reference Autodesk KB documents, you can use this syntax:
    http://support.autodesk.com/getdoc.asp?ID=<KB DOC #>
    So this one would be:
    http://support.autodesk.com/getdoc.asp?ID=TS7318
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    I have heard a lot of complaints about complex linetypes when text is used in the definition. Most of the complaints are due to the fact that when the text style properties are changed they affect the text in the lines.
    I would recommend looking at creating your own shapes for your complex linetypes. I did this by tracing over the text with a polyline then using the MKSHAPE express tool to turn the polylines into a shape.
    Just my 2 cents.
    Earth
    9,803
    Quote Originally Posted by jpaulsen
    Just my 2 cents.
    Good comment. We have done this also.
    The other alternative is to create a special text style for text in linetypes. This still suffers from the problems you mentioned, but it's one step better than using STANDARD.
  1. 2014: Create a custom linetype with two colors
    By boyerd492098 in forum AutoCAD General
    Last Post: 2015-05-23, 10:22 PM
  2. Replies: 5
    Last Post: 2013-06-25, 12:40 AM
  3. Extract Linetype information from a custom Linetype
    By H.Hunter in forum AutoCAD Customization
    Last Post: 2006-08-15, 05:27 AM
  4. Create a custom linetype with an Arc in it
    By tyeelaw13 in forum AutoCAD Customization
    Last Post: 2006-07-14, 03:49 PM
  5. create linetype
    By Rebecca Cooper in forum VBA/COM Interop
    Last Post: 2005-04-19, 09:31 PM
