Results 1 to 10 of 19
Thread: Turn off OLE frame in AutoCAD 2004
    2005-08
    44
    Question Turn off OLE frame in AutoCAD 2004
    Can someone please help me understand how to turn the frames off an OLE object?
    I have this one computer that started to show the frames on the OLE (Word document) object. This is new and did not happen before. All the other machines in the office can plot the same file without showing the frame except this one?!
    I can't find any publication to solve this issue and the "OLEframe" command is only introduced in 2005.
    Thanks
    0,0,0 The Origin
    8,570
    Default Re: Turn off OLE frame in AutoCAD 2004
    Going by (dodgy) memory here - I think you left-click inside the document then right-click on the frame and select Frame Off or similar.
    John B
    13,656
    Hi "okonforti.91529" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the AutoCAD Customization forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    13,656
    Hi
    If additional information is required, try HERE.
    Have a good one, Mike
    Earth
    9,788
    Quote Originally Posted by okonforti.91529
    Thanks
    See Tip #6 here [ http://new.cadalyst.com/newsline/issue.cfm?issue=200419 ]
    R.K. McSwain | CAD Panacea |
    13,656
    Quote Originally Posted by rkmcswain
    Hi
    Only good for AutoCAD 2005 or above users; unfortunately OLEFrame will not work for "okonforti.91529" ( Sorry, I do not know your real name ), as stated in his / her original post...
    <SNIP>
    Plus, thread title used - Turn off OLE frame in AutoCAD 2004
    Earth
    9,788
    Quote Originally Posted by Mike.Perry
    Mike,
    Yes, I read the thread title, and yes I read the original post.
    Now please read the entire tip at the URL I posted. It specifically addresses the persistance of a frame on OLE objects in "earlier than 2005" versions and how to fix.
    13,656
    Mike,
    Hi
    Ok! here is the complete tip you referenced in your above post...
    6. AUTOCAD 2005 TIPS: OLE FRAME FRUSTRATION, SHEET SET SPY
    A new system variable in AutoCAD 2005, OLEFRAME, may cause problems when you insert an OLE object in AutoCAD 2005, then open the drawing in an earlier version of AutoCAD. When you plot the drawing in the earlier version, the OLE object may have a frame that's impossible to get rid of. To fix, open the drawing in AutoCAD 2005 and reset OLEFRAME to 0. Thanks to Leonid Nemirovsky at BTN (Better Than Nothing) AutoLISP:
    http://home.pacifier.com/~nemi
    And one from Autodesk: Stymied by a locked sheet set? Move your mouse cursor over the icon to see a tooltip with the user name and computer name of whoever has it locked.
    Maybe I am missing something here ( mostly likely ), but the solution offered in the above tip appears to be open the drawing in AutoCAD 2005 and reset OLEFRAME to 0.
    Please correct me if I am wrong on this.
    Earth
    9,788
    Ok, since you quoted it (I didn't want to do this due to copyright issues - it does say "Copyright (c) 2003 by CADALYST Magazine. Reproduction or distribution in whole or in part without written permission is prohibited." )
    Yes, the solution is to open in 2005 and change the variable. The cause is also stated - this variable was set while the drawing was being edited in 2005.
    Just because a person is not "2005 user" doesn't change the fact that this is a solution. We don't know the history of this drawing. It very well may have been opened in 2005 at some point in it's life and had OLEFRAME set to 1
    2004-07
    Detroit Michigan
    2,508
    If ole frame is turned off, then can the object still be selected?
  1. Replies: 0
    Last Post: 2011-11-15, 10:31 PM
  2. Render and Wire Frame Modeling in AutoCAD 2004
    By Deogan in forum AutoCAD Gallery
    Last Post: 2007-08-25, 03:55 AM
  3. Replies: 5
    Last Post: 2007-05-04, 03:49 PM
  4. Replies: 21
    Last Post: 2006-12-16, 05:44 PM
  5. Replies: 4
    Last Post: 2005-06-29, 06:30 PM
