Thread: Lot Coverage
    All AUGI, all the time ford347's Avatar
    2005-01
    Oroville, CA
    874
    Default Lot Coverage
    Is it possible to do a lot coverage schedule combining your gross building areas against your site square footage? I would like to express this in a schedule. Is this doable? If not, would it be best to just create some calculated values to accomplish this?
    Thanks
    Josh
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Lot Coverage
    If you put a pad(s) under your building, and it's size equals the gross building footprint, you can do a topo schedule that will report out the topo projected area and the building pad area.
    2005-01
    Oroville, CA
    874
    That's a good idea. I'll try that. For the meantime, I went ahead and created a property lines schedule, threw the area parameter in there and made a calculated value for Gross Building Areas, so you have to fill it out in the schedule yourself, but the result gives a percentage just like I needed. It would be nice to have it linked like you suggested though. Thanks!
    Josh
  1. Sprinkler Head Coverage Area
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2021-07-21, 03:24 PM
  2. Overhead Coverage System
    By scott.jeffers in forum AutoCAD Gallery
    Last Post: 2009-04-03, 02:21 PM
  3. Importing ArcInfo Coverage
    By malfan in forum AutoCAD Map 3D - General
    Last Post: 2007-12-13, 08:12 PM
  4. Lot Coverage Calcs in Schedule
    By iru69 in forum Revit Architecture - General
    Last Post: 2005-06-30, 03:47 PM
