phyllisr
Just curious. When you did this (we did something similar so we can group our sheets according to NCS method), how did you create your parameter? Did you use an integer? Once you created the parameter, did you assign sequential numbers to each sheet? If so, and you added a sheet, how did you avoid renumbering everything? What did you do about consultant sheets.
We have a method that solves this (and as soon as I get this documented in some clear fashion and the tutorial created for our users, I will share) but I am curious what methods others are using to get the sheets in order. For me, the trickiest was getting our consultant sheets in our set (particularly when they come as PLT, PDF, TIFF or other), getting the index for everything as a single entity instead of bunches of little schedules, and figuring out how to avoid renumbering everything when one page was added to a several hundred sheet set. Ended up with one INDEX schedule (for the sheet itself with all the stuff hidden) and an INDEX MANAGER schedule to organize everything but ultimately got it to work effectively. Seems better than lots of filtered schedules and seems we can pre-load into our template also.
Just interested in how you addressed these issues. Thanks.
