Thread: Using Disciplines
    Member Chirag Dedhia's Avatar
    2005-05
    Mumbai, India
    37
    Default Using Disciplines
    Tthe organisation is working with many in-house depts, we have enabled worksets for them. The Architectural Team uses "Architectural" as a discipline in the Floor Plans and the Electrical Team uses "Electrical" as discipline. With disciplines we thought it would be easy to manage our drawings in the Project Browser. Till here we are through.
    When we see a Electrical Plan, the entire layout (architectural as well as electrical) is completely grayed out.(Note discipline for this view is set to electrical). With that even the Electrical Symbols and Detail Lines are also grayed out, which shouldn't be the case!
    Any help on this would be appreciated.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Using Disciplines
    check the phase setting on your elec. plan and see if it is set to a newer phase than your other plans. Or make sure halftone isn't checked in VV.
    Scott D. Brown, AIA
    BECK
    2005-05
    Mumbai, India
    37
    Scott, i checked that there is nothing checked as halftone in the visibility and neither have phases been used in the project. The phase filter and the current phase are as they are in the architectural drawings.
    Check the attachment.
    2005-05
    Mumbai, India
    37
    Any Help on this??
    2001-12
    Irvine, CA
    7,567
    Quote Originally Posted by Chirag Dedhia
    ...With that even the Electrical Symbols and Detail Lines are also grayed out, which shouldn't be the case!...
    I believe this is a bug in Revit Systems and therefore seems to have made its way into the function of Revit Building as well. Contact Revit support to discuss this.
  1. More Disciplines
    By Garn in forum Revit Architecture - Wish List
    Last Post: 2021-04-01, 02:53 PM
  2. add disciplines to a project.
    By dmorin in forum Revit Architecture - General
    Last Post: 2010-11-26, 10:48 PM
  3. MEP Disciplines
    By zeller in forum Revit MEP - General
    Last Post: 2009-07-23, 07:48 AM
  4. disciplines
    By Davied2 in forum Revit Architecture - General
    Last Post: 2006-03-31, 12:43 PM
  5. Disciplines
    By robmorfin in forum Revit Architecture - General
    Last Post: 2005-01-04, 05:28 PM
