This is my first thread.
I am working on Autodesk MAP and new to lisp.
I want to extract the Data attached to object
(Map->Object Data->Attach/Detach Object Data) and print them on grphscreen,
mainly as a checking tool.
Pl help me.
Pl help me.
Hello there,Originally Posted by snviswanadha
Welcome to AUGI. I'm afraid I don't use Autodesk MAP, however I do feel sure that a forum moderator may be along any time now to move this thread to a suitable forum to get you some answers.
Nice meeting you,
The Autodesk Map APIs include ActiveX, AutoLISP, ObjectARX, ObjectARX Managed Wrappers, and Feature Data Objects (FDO).Originally Posted by snviswanadha
ObjectARX is a C++ API. ObjectARX Managed Wrappers is the managed C++ equivalent.
FDO, like ObjectARX, comprises both a C++ API and a managed C++ equivalent.
ActiveX and AutoLISP Help
The following Help files document ActiveX and AutoLISP, which are fully installed with Autodesk Map. These files are located in Autodesk Map 3D\Help.
Autodesk Map ActiveX Help => acmapatm.chm
Autodesk Map AutoLISP Help => acmaplisp.chm
I've written a routine that labels contours from GIS simular to what you're looking for. Send me your email address and I'll send it to you.
Thank you Mr.Tom Beauford here is my
email: snviswanadha@gmail.com
I am sending to your mail also
Originally Posted by Tom Beauford
(setq NumberOfTheRecord 0);; usually 0
(setq recID (ade_odgetrecord entity "ObjDataTableName" NumberOfTheRecord ))
(setq ReceivedData (ade_odgetrecfield recID "ObjDataField")
Mr.Snviswanadha
Find the enclosed file fulfill u requirement.
It is displays the properties of entities as well as object data also on graphic screen.
If u need any further assistance don’t hesitate ask me.
Start with disp...it will guides u further
Best Regards,
Prabhakar.B
Tahnk You,
Here I am a attaching a CogoLine_OBData.Lsp file which i worked on the Lisp file which i got from Mr.TomTom Beauford here I am getting the difference but when it comes to Angle (Bearing) the Cad returns like "N 59d25'40\" E" and I am entering as N59d25'40"E
always it is showing a error.
How can I get CAD information as N59d25'40"E.
Pl help me.
Could you send me the drawing you're using this on? Our GIS data is organised differently which prevented me from getting anything from your lisp. The function you're probably looking for is 'vl-string-subst'.Originally Posted by snviswanadha
Thank You,
Here I am attaching the Piece of DWG,the dimesions on layer PARCELS are the given one. The required fields for this are Length,Bearing,Parcel_ID,Block_no,Present_Owner,
Previous_Owner ectc.The length should be in +/- 3% tolerance.
