Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: The Visual Basic Editor in ACAD2006
    2006-04
    24
    Default The Visual Basic Editor in ACAD2006
    Autocad 2006 was recently put on our machine and I was wondering if the Visual Basic editor interfaces directly with Autocad. I have some experience programming with VB and I was wondering if there were special calls designed to issue commands to autocad. I was wanting to make a macro with a GUI.
    Thanks!!!
    Justin
    100 Club intergrupocr's Avatar
    2006-02
    116
    Default Re: The Visual Basic Editor in ACAD2006
    Type VBAIDE and you will go!!!!
    In the Help File are a lot of resources about ActiveX Automation!!
    Have a nice trip!!!!
    Turlock, CA
    6,453
    Since this is strictly a vba topic, I moved it here.
    C:> ED WORKING....
    LinkedIn
    2006-04
    24
    My bad, I'm pretty new here and didn't realize there was a forum dedicated to this.
    Thanks for sharing all these fantastic resources!
    However, the help file doesn't ever really help much.
    2006-02
    116
    Quote Originally Posted by justinxxvii
    You have to follow the link at the bottom of the help index
    ActiveX Automaion and VBA
    Then you will find this...
    2002-02
    Kansas
    487
    FORM THE HELP IN AUTOCAD 2002 IT THE SAME FOR 2006
    To update the coding examples for use with VB, you must first reference the AutoCAD type library. To do this in VB, select the References option from the Project menu to launch the Reference dialog box. From the References dialog box, choose AutoCAD Type Library, and then press OK.
    Next, in the code example replace all references to ThisDrawing with a user-specified variable referencing the active document. To do this, define a variable for the AutoCAD application (acadApp) and for the current document (acadDoc). Then, set the application variable to the current AutoCAD application.
    If AutoCAD is running, the VB GetObject function retrieves the AutoCAD Application object. If AutoCAD is not running, an error occurs that (in this example) is trapped, then cleared. The CreateObject function then attempts to create an AutoCAD Application object. If it succeeds, AutoCAD is started; if it fails, a message box displays a description of the error.
    Note: When running multiple sessions of AutoCAD, the GetObject function will return the first instance of AutoCAD in the Windows Running Object Table. See the Microsoft Visual Basic documentation on the Running Object Table (ROT) and the GetObject function for more information on verifying the session returned by GetObject.
    You must set the AutoCAD application's Visible property to TRUE in order to display the AutoCAD drawing window.
    Note: If GetObject creates a new instance of AutoCAD (that is, AutoCAD was not already running when you issued GetObject), failure to set Visible to TRUE results in an invisible AutoCAD application; AutoCAD will not even appear on the Windows taskbar.
    2006-04
    24
    Thank you.
    I started fiddling around with some of the functions but this visual basic isn't behaving like one I'm used to.
    I wanted to make a little app that would draw a line by clicking a button. The line would have properties that were defined in two text boxes:
    1. Distance
    2. Bearing
    and would use the command format
    @distance<nXXdXX'XX"e
    So I created variables in the module
    Dim distance as Integer
    Dim bearing as String
    And then I wanted to create the routine
    Sub bearingline (distance, bearing)
    and this is where I got hung up. There is a line routine here called "AcadLine" but I can't figure out how to use it. I would like to call up the line command, and then use some programming to make the line go for the specified bearing and distance.
    how does AcadLine work? I'll start checking help files and websites but I just want to see if anyone can help me here.
    Thanks ladies and gentlemen
    Justin
    EDIT:
    nevermind I've found out more information, there are properties for acadline called "length" and "angle"
    So I will fiddle with it some more
    Earth
    9,809
    Calculate the endpoints of the line, then create it.
    Here is a small example
    Sub myLine(brg As Double, leng As Double, pt1 As Variant)
    Dim pt2 As Variant, newline As AcadLine
    pt2 = ThisDrawing.Utility.PolarPoint(pt1, brg, leng)
    Set newline = ThisDrawing.ModelSpace.AddLine(pt1, pt2)
    End Sub
    Sub foo()
    pt1 = ThisDrawing.Utility.GetPoint(, "Pick Start Point")
    Call myLine(1.3, 3.5, pt1)
    End Sub
    The Angle and Length properties of an existing line are read-only.
    R.K. McSwain | CAD Panacea |
    2006-04
    24
    Wow thanks! I was wanting to take a shot at coding this but I didn't know how all those properties worked.
    You pretty much did all the work for me, thanks, this is exactly what I was looking for.
    I will fumble around with your code to ty to customize it
    2006-04
    24
    I'm not understanding the code here.
    This part:
    I'm sending the bearing information and the length information into the sub.
    Then this:
    So ThisDrawing.utility.polarpoint (Starting Point, Bearing information, length information) will calculate the endpoint?
    So now I can
    Why did you write this code in:
    What do the 1.3, and 3.5 represent? Are they arbitrary figures or do they mean something else? Shouldn't it be Call myline (brg, length, pt1)
    Or will this not work?
    I can't get the code to work correctly, first I copied the sub information into the bas, then the foo routine into a command button, and sent textbox1.text and textbox2.text into it for brg and length
    EDIT
    Ok I see something now, when I type
    set newline = ThisDrawing.modelspace.addline (
    an info box pops up and says "Start Point, End Point"
    What is an easy way to calculate the endpoint with a bearing and distance?
    EDIT:
    I guess there is another function in here called PolarPoint which is supposed to calculate my endpoint. I will have to convert my bearing into an angle by using another feature called deg2rad or something, but I will continue working
    I'll post again if I figure it out
  1. visual lisp editor should be like visual studio
    Last Post: 2011-11-17, 05:33 PM
  2. Autocad LT vs Visual Basic 6
    By hibbe.wiersma172517 in forum ARX
    Last Post: 2008-08-21, 08:16 AM
  3. The future of Visual Basic
    By MikeJarosz in forum VBA/COM Interop
    Last Post: 2006-08-04, 06:29 PM
  4. Microsoft Visual Basic
    By jcronburg in forum VBA/COM Interop
    Last Post: 2004-06-16, 07:49 PM
