Results 1 to 6 of 6
Thread: 3D Meshing and Solids
    2004-06
    Cool 3D Meshing and Solids
    Is it possible to convert 3D objects created with surface meshing to 3D solids?
    2015-12
    Arizona
    2,351
    Default Re: 3D Meshing and Solids
    From the following Knowledge base article it seems that it
    is a 'one-way' street. And from your description of what you want to do
    you are going the wrong way! At least where autocad is concerned.
    Three dimensional objects, including regions, solids, meshes, objects drawn by extruding or revolving, Boolean operations, and solid models can all be converted into polyface meshes or 3D faces.
    Solution
    To convert these type of objects:
    Use the 3DSOUT command to export objects from a drawing. Use the default settings.
    Open a new drawing.
    Enter 3DSIN on the command line.
    Select the new drawing you just created.
    From the 3D Studio Import Options dialog box, choose the Add All button.
    Choose OK.
    The objects will load into the drawing as polyface meshes.
    To create 3D faces from the polyface meshes, explode the polyface meshes.
    13,656
    Hi
    Check out the lisp file m2s.lsp (can be found at any of the following locations) -
    xarch AutoCAD
    Eng-Tips
    VIZiKOS
    accustudio
    You may want to take a look at this -
    AuxiSystems, Inc. Surface to Solid Conversion Service
    Have a good one, Mike
    100 Club Vincent Valentijn's Avatar
    2003-07
    netherlands
    188
    Exclamation Re: 3D Meshing and Solids
    M2S stands for Mesh to Solid I presume? I can tell you that the lisp doesn't work for AutoCAD 2005...
    Command: appload
    m2s.lsp successfully loaded.
    Command: ; error: malformed list on input
    13,656
    Hi
    M2S.lsp has a Copyright notice within it's header therefore I suggest you contact the person (there are a couple of contact E-mail addresses within the header) and see if they have an updated version or are willing to update the routine for AutoCAD 2005.
    Active Member treb's Avatar
    2002-07
    Toronto
    75
    there used to be a command called solidify, but I cant remember if it worked with meshes
    (old r12 stuff)
  1. Replies: 2
    Last Post: 2015-09-11, 08:57 PM
  2. AU201-1L: Meshing Around With AutoCAD
    By Autodesk University in forum AutoCAD
    Last Post: 2014-11-17, 05:28 AM
  3. 2014: Meshing issues
    By ronny_raygun371629 in forum Robot Structural Analysis
    Last Post: 2013-04-26, 02:32 PM
  4. meshing problems
    By strozy in forum Robot Structural Analysis
    Last Post: 2010-07-07, 02:03 PM
  5. Surfacing with Nurbs Meshing
    Last Post: 2007-09-04, 03:54 AM
