Results 1 to 10 of 10
Thread: UCS Icon equivalent
    I could stop if I wanted to raddis's Avatar
    2015-12
    208
    Default UCS Icon equivalent
    Is there anything in Revit I can turn on to show me my orientation, especially in 3D?
    AutoCAD has the UCS icon, which makes it easy for me to figure out my current view direction.
    When opening files that start in 3D, it's difficult to tell the view direction. Am I missing something (don't get cute!)?
    Regards,
    Reid M. Addis
    Registered Architect
    Addis Computer Consultants
    330 Bryn Mawr Avenue
    Bala Cynwyd, PA 19004
    Cell. 610-996-9666
    email: raddis@addiscomputer.com
    2015-12
    Vancouver, BC Canada
    3,753
    Default Re: UCS Icon equivalent
    Easiest way I can think of is to draw a simple north arrow using model lines. They are visible in all views.
    I could stop if I wanted to rkitect's Avatar
    2006-01
    449
    I don't see any options that contain anything about [UCS like] orientation.Of course, there are the options under 'View > Orient' that allow you to orient the model to a certain cardinal direction or orthagonal view.
    HTH,
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Hmm...I lost what I began writing...oh well...
    Cute? I will try not to get cute, although difficult.. LOL
    There is no UCS Icon...actually there is no UCS perse.....When you are in 3d, there isn't a need for an icon, because there is no UCS like in Autocad...and there is no WCS either....at least not directly...
    Each object has its coordinate system, so if you move something, it moves per it's own coordinate system...unless it is a free object (not controlled by a plane)
    If you want, you can turn on the work plane on (a type of UCS)
    From the pulldown menu go to "Tools/Work Plan/Work Plane visibility" or the tool bar (second toolbar line and second from the left)
    I erased the UCS and UCS Icon and WCS and changing UCS from my memory bank...and have been quite happy....that's as cute as I will get...
    Hope some of this helped...
    Take care,
    Quote Originally Posted by raddis
    2015-12
    208
    Well, the point was "how do I know I'm looking at the NorthEast or SouthWest view", but I guess we are just on our own.
    Regards,
    Reid M. Addis
    Cell. 610-996-9666
    2003-04
    Chino, CA
    4,756
    Best way to know, it to create a view and name it. Starting with a 3D view, View>Orient>Southwest will get you a Southwest oriented "axon" (relative to north being 90 degrees vertical in the main plan view) that you can name Southwest. Do the same for the other 3 "axon" directions. Now you can easily switch between them, and they are named so its easy to tell.
    Scott D Davis
    Sr AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2015-12
    208
    .....when opening someone else's file, or a family for editing that is left in 3D.
    I guess I'm asking for too much here.
    Thanks.
    Regards,
    Reid M. Addis
    Cell. 610-996-9666
    2015-11
    Royal oak, Michigan
    1,513
    There is no ucs icon. In autocad if you open someones drawing and view it in 3d, you may, or may not, be seeing the WCS...it may be the UCS, and in that sense, you still don't have certainty where north is. You have to be certain that north is up or right, then make sure you are in the WCS and not the UCS, and then have in mind, while looking at the UCS icon where north is (up or right, or whereever)
    on a side not, is the north, East, West, South views of the building so identical that you can't figure out which view you are looking at?
    If you really want to have something, like an icon in autocad...then do what was suggested earlier...create a north arrow with model lines as a family....give it a special subcomponent so that you can easily turn on or turn off and make sure that everybody in your office adds it to each project, and have them properly rotate it so that the arrow points north....it can be a big circle diameter (like 100' or 200') and placed on the 1st level (bottom of building, or on second thought...maybe the top) so when in 3d view you will see it....
    you may need a couple of projects to strategically size the north arrow....but that may help you.
    2002-02
    St. Louis, MO
    4,695
    Quote Originally Posted by Scott Davis
    ...to follow up on Scott's note. A Saved 3D view can be spun around while working, but will reset to the save view after the view is closed. So each time it is displaying the correct stuff.
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    2006-01
    4,516
    Another method could be to just make a N-S reference plane. If youre in 3d, set your work plane to it, and turn on work plane visibility.
    I dont use WPV as a UCS, but its great for finding stuff in 3d, lol...
  1. Équivalent de Regénérer
    By Tony D. in forum Revit Architecture - Général
    Last Post: 2010-01-29, 10:28 AM
  2. DWGDirectX equivalent
    By michael.hooker in forum Dot Net API
    Last Post: 2008-12-23, 04:18 PM
  3. inageclip equivalent
    By tect75 in forum Revit Architecture - General
    Last Post: 2007-10-22, 09:13 PM
  4. Tool Palette Icon not matching Toolbar Icon
    By bowlingbrad in forum AutoCAD Customization
    Last Post: 2005-11-02, 08:10 PM
  5. Is there an AU equivalent out there??
    By mikesal in forum CAD Management - General
    Last Post: 2005-08-05, 02:27 PM
