Results 1 to 1 of 1
Thread: Scale bug on Titleblock?
    2005-07
    3,250
    Question Scale bug on Titleblock?
    The scale parameter on a titleblock typically changes to whatever view is placed on a sheet. So if you place a 1/8" plan/elevation view (or more views of the same scale), it changes to 1/8". If you have two views that are not the same scale, it changes to "As Indicated".
    I placed a number of 3D views oriented by the face of mullion plane (to show curtainwalls in elevation without having to drop a ton of new elevation tags around, which I would then have to maintain in each view by hiding the annotation...). These views are at 1/4" but the Scale parameter on the titleblock doesn't fill out. Why doesn't it work? See image attached.
  1. Change text 'as indicated' with 'scale'parameter on titleblock?
    By studiodd in forum Revit Architecture - Families
    Last Post: 2011-10-25, 05:04 PM
  2. Scale in titleblock can we change "As Indicated"?
    By vaughndave in forum Revit Architecture - General
    Last Post: 2008-05-27, 08:06 PM
  3. Scale default setting in Titleblock
    By amandas in forum Revit Architecture - General
    Last Post: 2007-03-03, 02:02 PM
  4. Metric titleblock does not scale properly
    By stephane.laferriere in forum Dynamic Blocks - Technical
    Last Post: 2006-08-05, 06:42 AM
  5. Convert 2436 titleblock to 3042 titleblock?
    By m_cahoon14336 in forum Revit Architecture - General
    Last Post: 2004-08-23, 04:45 PM
