Thread: Paint problem
    2003-08
    Ann Arbor, Michigan
    121
    Default Paint problem
    I am trying to paint some split face regions on a wall.
    I successfully used the paint tool in some areas.
    When I try to use it in adjacent areas the painted material doesn't show. When I hover the paint can to highlight these areas the little message box pops up and indicates that the proper material has been applied to the area, but it doesn't show.
    Help, please!
    Thanks.
    Mike
    All AUGI, all the time ford347's Avatar
    2005-01
    Oroville, CA
    874
    Default Re: Paint problem
    What view are you trying to paint in? I have done this before and swear I am splitting the right region and painting the right region and it turns out for some reason, when I was tabbing to get to my split region, I had selected an area behind it on another wall, way behind it, like the other side of the building. I was doing this in a 3d view, so I positioned the drawing in a different position, re-drew my split lines and got it.....long shot maybe, but I did it a time or two, so hope that helps....other than that, I have no idea. Sorry.
    Josh
    2003-08
    Ann Arbor, Michigan
    121
    Josh,
    Thanks for your reply.
    I was doing it in an elevation view.
    I will try a 3D view.
    Mike
    2003-08
    Ann Arbor, Michigan
    121
    I looked in a 3D view and I see that the inside face is getting painted, not the exterior.
  1. Moving paint
    By charliep in forum Revit Architecture - General
    Last Post: 2012-08-02, 01:52 PM
  2. Paint puissance 100
    By mikL44 in forum Français - Récréation
    Last Post: 2011-07-28, 09:09 AM
  3. Paint Icon
    By anthony.67953 in forum Revit Architecture - General
    Last Post: 2010-06-07, 12:50 AM
  4. Paint
    By Jun Austria in forum Revit Architecture - General
    Last Post: 2009-09-02, 01:22 AM
  5. Paint Packages
    By Roger Evans in forum Revit - Rendering
    Last Post: 2004-10-14, 01:53 AM
