Express Tools do not display, are missing, do not work, etc.
The below information might just help resolve such issues / problems....
Links:
Autodesk Knowledge Base:
ID: TS26655 - Express tools are installed but the menu does not display
ID: TS43616 - Express Tools are not listed on menu
ID: TS44971 - Express Tools no longer load
ID: TS59037 - Migrate Express Tools from AutoCAD 2000 to AutoCAD 2000i or AutoCAD 2002
ID: TS59827 - ACET-CMD-CHECK error when running AutoCAD 2000 software after installing Volume 9 of the Express Tools
ID: TS64921 - Availability of AutoCAD Express Tools for AutoCAD 2002 software
ID: TS65773 - AutoCAD Express Tools do not work after importing profile
ID: TS70705 - Error: no function definition: ACET-STR-FORMAT
ID: TS80219 - Express Tools not installed after product is pushed by Group Policies
ID: TS80434 - Second installation of AutoCAD 2004 based product does not contain Express Tools
ID: TS83144 - Error installing AutoCAD 2004 Express Tools
ID: TS1050281 - AutoCAD 2006 Express Tools menu does not display
AUGI Forum:
Missing Express Tools in AutoCAD 2004
Express tools - didn't reload?
Express Tools don't stay loaded in AutoCAD 2004
Installing Express Tools in AutoCAD 2005
Loading Express Tools in ADT 2004
Reload unloaded Express Tools
Express Tools - Error loading acetutil.arx file
Loading Express Tools into AutoCAD Map 5
What happened to my express tools?
AutoCAD 2006 Express Tools error - unable to load acetauto.lsp/fas
Express Tools command not working through menu is loaded
AutoCAD 2006 Distribution Wizard and installing Express Tools
Loading Express Tools in ABS 2006
Import Express Tools in AutoCAD 2002
AutoCAD 2004 - Install Express Tools
How to install Express Tools
Installing express tools in ABS 2006
AutoCAD 2004 - Lost Express Tools
Installing Express Tools in 2006
Express menu missing, how do I get it back
Where are the Express Tools (AutoCAD 2006)
Reloading Express Tools menu in AutoCAD 2006
Getting Express Tools to work in ADT 2004
AutoCAD 2006 - Express Tools not migrated from AutoCAD 2005
Install Express Tools with AutoCAD 2005
Express Tools do not function / work on some machines
AutoCAD 2007 - Missing Express Menu
ADT 2006 - Express Tools icons showing as "?"
Getting Express tools to work with AutoCAD 2006
Express Tools menu does not show up in AutoCAD 2006
AutoCAD 2007 Express Tools menu missing
Express Tools not working in AutoCAD 2004
Express Tools missing from ADT 2006
AutoCAD 2007 - Express Tools not showing up
Express tools not working in AutoCAD 2007
AutoCAD 2004 Express menu gone south
AutoCAD 2007 can not locate Express Tools pulldown menu
Express toolbars gone missing in AutoCAD 2008
Express Tools - error: no function definition: ACET-AUTOLOAD
