Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Help finding the relevant Block so Layer 1 can be Purged
    2003-02
    62
    Question Help finding the relevant Block so Layer 1 can be Purged
    I have to work on lots of drawings with bad CAD practices, especially where Blocks are concerned. They created a Block on "whatever" layer(instead of "zero") they were working on, or maybe someone else created it years ago, & now it has been inserted into a new drawing on a different layer.
    Is there a way to quickly find this single block, with unknown name,in the drawing? I can't find the Block, Merge or Purge the layer on which it was created.
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Help finding the relevant Block so Layer 1 can be Purged
    Quote Originally Posted by bjack56
    if you have 2006 or 07, you can type in 'BE' (block editor) and maybe walk thru the inserted blocks. once found, you can instantly fix.
    Sometimes, i get lost in my own thoughts and need to ask directions to find my way back.
    S&D DB Sharing Forum
    2001-12
    St. Louis
    5,408
    If I am reading your question correctly, I think you might find some helpful information in the following threads:
    Changing block entities' color to bylayer
    batch modification of block properties
    Colors Bylayer
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2003-02
    62
    I'm using 2002 right now which gives the following message for Layer Merge Express Tool. Tried Merging to layer "zero".
    Layer 1 could not be purged because it is being referenced by some object(s) in the drawing.
    2001-12
    St. Louis
    5,408
    hmm... sorry for my previous answer, I definitely read that wrong, have you tried doing a QSELECT for all entity types on 'Layer 1'? In theory, then you could find the offending block that way. good luck.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    9,805
    Post or email me the drawing if you wish.
    2003-02
    62
    Tried QSELECT with no luck. I am not too familiar with using it though, so might not have done properly.
    2002 format dwg attached...I hope.
    0,0,0 The Origin
    8,570
    The block A04119 contains a layer "1".
    9,805
    Quote Originally Posted by jaberwok
    The block definition or an insertion of that block is on "1" ?
    0,0,0 The Origin
    8,570
    Quote Originally Posted by rkmcswain
    The block definition.
  1. Finding out why an item can't be purged.
    Last Post: 2019-03-29, 03:18 AM
  2. 2015: Find command not finding field values in dynamic block
    By jpcadconsulting347236 in forum Dynamic Blocks - Technical
    Last Post: 2017-07-27, 07:56 PM
  3. Finding a block within a drawing
    By csorensen in forum AutoCAD General
    Last Post: 2010-06-09, 04:13 PM
  4. Is RMEP relevant?
    By Liamnacuac in forum Revit - In Practice
    Last Post: 2009-02-06, 06:03 PM
  5. Finding objects on a particular layer
    By zride91 in forum AutoCAD General
    Last Post: 2008-09-10, 12:31 PM
