Thread: Using Open Type fonts in AutoCAD LT 2006
    2005-09
    Where am I?!
    5
    Default Using Open Type fonts in AutoCAD LT 2006
    Recently I was handed a project that involves using our company font in the drawing. AutoCAD 2006 LT has no problems using true type, but what about open font? I have tried to figure a work around & the only option I have found is typing in Word or Excel & using the copy command then pasting in the drawing. The problem with that is that I also get the background from Word or Excell in my drawing & it just looks like a huge rectangle. Is there anyway to get LT2006 to recognize open fonts or am I stuck tracing the font after imported into my drawing?
    9,802
    Default Re: Using Open Type fonts in AutoCAD LT 2006
    Have you searched the Autodesk KB?
    http://support.autodesk.com/
    This article addresses your issue:
    http://support.autodesk.com/getdoc.asp?ID=TS79744
    2005-09
    Where am I?!
    5
    Issue
    After you installed an Open Type font in Windows, the font was not displayed as an option in any of the dialog boxes in the program.
    Solution
    Current products do not support the use of Open Type fonts in text editing or creation dialog boxes.
    uh oh...looks like I'm stuck tracing. hopefully they patch this in the near future
    as open fonts is gaining popularity.
    thanks for quick response
  1. Open Type Fonts
    By blads in forum Revit Architecture - General
    Last Post: 2009-03-10, 04:58 PM
  2. Load True Type fonts for use in AutoCAD 2006
    By rduprey in forum AutoCAD General
    Last Post: 2008-10-03, 08:19 PM
  3. Does AutoCAD support Open Type Fonts?
    By mcervantes in forum AutoCAD General
    Last Post: 2007-05-07, 01:57 PM
  4. Using Open Type Fonts in AutoCAD
    By Kid-Zort in forum AutoCAD General
    Last Post: 2006-08-31, 04:39 PM
  5. Can I use Open Type Fonts?
    By cmahoney in forum Revit - FAQ (Read only)
    Last Post: 2005-02-23, 02:29 PM
