Thread: Setting up company standard Templates, what should go in them
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Question Setting up company standard Templates, what should go in them
    I am starting to put together a first draft standard for our office and am working on getting a template together, but im not quite sure what goes into the drawing template, and what should be in seperate files.
    i know dim styles, text styles, layers etc all go in the template - but what about AEC object styles? should they be in a seperate drawing per object type (one for walls, one for doors / windows etc) or just part of the basic template?
    Member Nashville's Avatar
    2005-12
    5
    Default Re: Setting up company standard Templates, what should go in them
    Quote Originally Posted by Chad_C
    I work for a property development company in London, England.
    I have set our CAD standard in away that I feel that its the easyest way poss.
    I have included some of the following:-
    A list stating the CTB we use, line thickness etc..
    A diagram stating our network set up.
    It should be basic, so that any out sider of your company, could join your company and be able to start work using this set of guide lines.
    If you need any other pointers let me know, by the way if you come across a member called Bob Kalsi, I think Sammie the moderator knows him. He uploaded my manual so keep an eye out.
    James
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,193
    Quote Originally Posted by Nashville
    James
    I believe you are referring to this manual.
    All AUGI, all the time Avatart's Avatar
    2004-06
    Upsidedown in dreamtown
    928
    When you say template, are you referring to a .DWT file or a document template?
    If it is a drawing template, then it should have the absolute minimum information, dim and text styles for each scale you use, linetypes and that's about it. You may want to have a few templates available to your users, different ones for different drawing types and make them easily accessible over the Intranet or Network drives.
    For ADT stuff, I find it best to keep an office DWS (Standards file) and a project specific one, that usually stops people over-writing styles that are typical for all projects with one for a specific project.
    2006-04
    1,129
    thanks =)
    (stupid minimum character requirements)
  1. Replies: 0
    Last Post: 2015-08-07, 03:55 PM
  2. 2014: Setting Up Project Templates & View Templates???
    By sbrennan in forum Revit MEP - General
    Last Post: 2013-08-29, 09:17 PM
  3. Standard AutoCAD templates
    By Mac Demer in forum AutoCAD General
    Last Post: 2010-01-24, 07:07 AM
  4. Replies: 23
    Last Post: 2009-08-06, 10:55 PM
  5. Standard templates
    By archdraught in forum ACA General
    Last Post: 2008-03-12, 08:13 PM
